What battery to get
chbronco   1 mW
What battery to get
Post by chbronco » Mar 26 2020 8:34pm
Have this battery it's from a surface 604 fat bike about 3 years old need a new battery but it has a bunch of wires coming out of the other end of the battery, all the ones I see just have the 2 power wires
chbronco   1 mW
Re: What battery to get
Post by chbronco » Mar 26 2020 8:45pm
For some reason can't post a pic but have 2 main power wires on one end and 3 2 wire plugs coming out of the other end going into a 3"×3" box that's all in the battery
markz   100 GW
Post by markz » Mar 26 2020 9:21pm
Yeah, its probably proprietary which means you have to buy Surface's battery. They got you by the balls and you gotta pay up.
There maybe some simple hacks that might be found online or Endless Sphere somewhere. Its probably a very simple hack. Do some interweb searching and ES searching and see what comes up, I am sure we would all be interested in seeing your search results as Surface seems to be a popular brand of proprietary ebike.
If there is no fix, you could just use Surface's motor, buy a new controller and a new battery and your good to go. What is the power rating of the motor? Is it a Banfang 8 fun? Which would be like what, 500-1kw, geared most likely. So yeah do that and get back to us.
chbronco   1 mW
Post by chbronco » Mar 26 2020 10:54pm
Thanks for the reply, but it's not a bang 8 fun EBR has a reveiw on it its surface 604 element the vid is 6 years ago.But my bike has different parts 3ring crank 48v 12ah different speedometer but the hub motor looks the same Bought it as a demo I only maybe put on 10 charge cycles.But a bigger battery.
goatman   10 kW
Post by goatman » Mar 27 2020 12:18am
chbronco wrote:
Mar 26 2020 10:54pm
if you go to imgur and join for free it will resize your pictures for message boards. if the batteries dead are you comfortable just replacing the cells yourself ? you haven't mentioned if the battery still works or just dead. so ill just brainstorm dead battery
do you have a digital multi meter? big wires should be power, the other end you have 3 plugs that are 2 wires per plug, right?
is there an on/off switch on the box? or charging port? im trying to think what would be in that box.
1 set of wires might be for charging, 1 set for thermal shut/off(battery gets too hot) 1 set for battery gauge or bms on/off switch?
im just wondering if something in that box has shut off your bms
sounds like bms is in the battery
I would check for voltage on each of the 3 plugs.
pictures, a little more info and people will start helping you.
chbronco   1 mW
Post by chbronco » Mar 27 2020 10:30am
Yes I will do that,just thought some one on here would have had one and has modded it.
dogman dan   100 GW
Post by dogman dan » Mar 28 2020 8:06am
Put any picture into Microsoft paint, and then you can just resize it.
You may have to look into replacing just the battery innards, keeping the electronics inside that make the battery proprietary.
Crudest method, running a wire from a new battery on a rack or whatever, into the box where it connects so it thinks its the original battery in there.
