Batec speed controller?
E-HP   1 MW
Re: Batec speed controller?
Post by E-HP » Jan 04 2021 9:11am
Teebie wrote:
Jan 04 2021 5:02am
Pictured below, here is another Batec Electric Series #1 model which happens to also have been downgraded to the Australian standard 10km/h maximum speed limit!!!
This this particular model was originally advertised as traveling a maximum 20km/h European speed limit prior to then being shipped to Australia!!! Despite this, do you see any other alternative way of resetting the maximum speed limit (within the picture) back to the original European speed settings even though this this particular model doesn’t have the 3x copper knobs available to turn clockwise, or would I still need to provide even more pictures to hopefully analyse, fingers crossed!?
Thanks!
Steve
looking at some diagrams from online manuals https://www.49bespoke.com/images/suppor ... NGLISH.pdf
It looks like the speed controller is located on the other side of your photo, the small box in your pic with what looks like a red logo on the side.
Teebie   100 µW
100 µW
Post by Teebie » Jan 07 2021 2:50am
Fingers crossed, here’s what could hopefully be the Batec Electric Series #1 speed module controller/circuitboard (located within the small compartment box) that can still be altered without any copper knobs to turn...🤞🏻
Teebie   100 µW
100 µW
Post by Teebie » Jan 07 2021 4:50am
Luckily, I also have the Batec "Rapid⚡️Edition" Series #1 (Kawasaki🔋Green) available which is still capable of speeds up to 30km/h, but I may have to now consider upgrading this base model version with the following 20" wheel conversion kit capable of speeds up to 65km/h...🏁
amberwolf   100 GW
Post by amberwolf » Jan 07 2021 5:16pm
The three places that speed controls would be setup would be in either the display/controller's setup screens (if it has any; they may be passworded or "secret menu") or the controller's internal programming (typically accessible only with the manufacturer software), or in the intermediate electronics between the throttle/PAS device(s) and the controller's actual throttle input.
Since the settings / programming are probably not accessible to you, my recommendation would be to trace the wiring out from the throttle/etc all the way to the motor controller board, and draw it out on paper if it's not a direct connection. This will help you find any parts between them that might be used to do speed limiting. If there arent' any, then it's likely you'd have to replace the controller/display unit to get a faster speed.
The motor itself is probably perfectly capable of doing what you want, if it would have done so with the non-australian-limit in place.
slow&furious   1 µW
Post by slow&furious » Jan 12 2021 7:34am
Hi!
I came here looking for way to totally unlock Batec Electric 1 speed limitation but i see that I have more information then posted here.
So, in batec electric 1 you need to take of the plastic cover - red
Then you can see 4 switches in the center - those are speed limiters.
Up to 6km/h - 1up, 2,3,4 down
Up to 10km/h - 2up, 1,3,4 down
Up to 18km/h - 3 up, 1,2,4 down
Up to 20km/h - 4 up, 1,2,3 down
I hope that someone will find a way to take of the 20km/h speed limit - its still to slow form me, or I will change this driver into another, from electric bike, without limitations.
Greetings from cold Poland!
Drive safe :)
SlowCo   1 MW
Post by SlowCo » Jan 12 2021 8:06am
slow&furious wrote:
Jan 12 2021 7:34am
Great username :D
Are there no other combinations that affect the speed like:
1 and 2 up, 3 and 4 down
3 and 4 up, 1 and 2 down
1 and 3 up, 2 and 4 down
2 and 4 up, 1 and 3 down
all up
all down
slow&furious   1 µW
Post by slow&furious » Jan 12 2021 8:10am
SlowCo wrote:
Jan 12 2021 8:06am
slow&furious wrote:
Jan 12 2021 7:34am
Great username :D
all up
all down
Unfortunately no, i tried different combinations without success.
Username inspired by Batec Electric #1 :wink: :wink:
SlowCo   1 MW
Post by SlowCo » Jan 12 2021 8:54am
Teebie wrote:
Jan 04 2021 5:02am
Thanks!
Steve
@Teebie: look at the solution above from slow&furious to get the maximum speed of 20km/h by setting the switch under the black shrink wrap to 4 up and 1 to 3 down.
That maximum speed could be programmed in with a maximum rpm of the motor in combination with the size of the wheel and tire.
My first thought would be to contact Batec and kindly ask them if its possible to program the controller to get rid of the restriction for "off road use"... :wink:
They might be helpful (but probably not :( )
slow&furious   1 µW
Post by slow&furious » Jan 12 2021 2:00pm
[/quote]
[/quote]
It's not a good business for them to release such information because they are selling Rapid for extra money, and this one is going 30km/h :?
Teebie   100 µW
100 µW
Post by Teebie » Jan 13 2021 3:24pm
Once😤again, it seems the Batec 2015 speed limiter doesn’t have any codes to switch, or knobs to turn...🐌🏁
Teebie   100 µW
100 µW
Post by Teebie » Jan 13 2021 3:25pm
Pictured below, the speed limiter on the "Rapid⚡️Edition" 2015 also seems to have the exact the same colour🎨arrangements going into the exact same plugs!!!
Teebie   100 µW
100 µW
Post by Teebie » Jan 13 2021 3:26pm
Maybe, in the early day’s the company originally had so many complaints from clients worldwide wanting to change the speed back to the original settings that they then gave their customers the opportunity to revert the situation (with the flick of some switches, or the turn of some knobs) on their own...🇪🇸
amberwolf   100 GW
Post by amberwolf » Jan 13 2021 6:09pm
It's pretty unlikely that they would do it for their customers, especially since they sell faster models, and have negative motivation for losing money by selling customer-adjustable lower-speed models that are otherwise functionally the same as the higher-speed models. Aside from their accountants, they probably also have lawyers that would object to this, as well. ;)
It is much more likely that they originally used controllers programmed by the controller manufacturer (which is almost certainly not Batec) for each different model. So they'd have to keep around a bunch of different models of controller, and ensure they don't get mixed up during build of the various Batec units.
Or they used programmable controllers, that then had to be individually setup for each model, with the risk of bricking the controller if anything goes wrong during the process, every time this is done.
Then they decided to use switches (taht probably simply ground or let float a few signal lines to the controller's MCU, in the same manner as a common 3-speed controller) to make it simple for the Batec factory workers to "instantly" setup each unit, choosing from a list of preset speeds, and to easily convert any unit to any other speed version if the need arose.
At some point the 3-pot design came up, probably to make each of the three speeds completley adjustable, to make it easier to satisfy changes in local laws for wherever they sell these. There is probably a chart that shows what "o'clock" position to put each one at for what speed, and then a simple offground spinup of hte motor to verify it's set right, with any fine adjustments able to be done then. A bit more complicated than the switches, but more versatile, and probably a lot easier and less error prone for the average factory worker to setup than hooking up a programming cable and using probably-glitchy software with poorly-designed menus and whatnot. ;)
Just speculation...but based on evolution I've seen of actual products that I do know some details about.
Teebie   100 µW
100 µW
Post by Teebie » Jan 14 2021 4:31am
So, does this unfortunately only mean I’d have to still acquire 1x 2015 Speed controller (Rapid⚡️Edition) which hasn’t been reprogrammed for the OZ🇦🇺market to gain anymore🏁speed???
amberwolf   100 GW
Post by amberwolf » Jan 14 2021 2:21pm
That depends on the results of the wiring/signal tests I suggested before; if you find anything between throttle and controller MCU then you can trace that out and post it here, and we can see if anything might be safely alterable. If the display/etc unit is between throttle and controller, you should do a voltage test at various throttle amounts (wheel off ground) and each of the "speed" settings, to see if the throttle signal is being modified by the display/etc unit before it gets to the controller. If it is, then that's what would need to be modified or replaced.
If you do have to get the "rapid" version controller, you may have to also get the other matching electronics for anything that is different between that and what you have.
Teebie   100 µW
100 µW
Post by Teebie » Jan 15 2021 3:56am
Pictured above, it seems the throttle wires travel directly straight into the speed🚫limiter board C5 pins (white/red/black) before then getting lost travelling to the speed controller box (then motor, etc.), or could the throttle wires (white/red/black) still possibly be the same colour arrangement within in the following speed controller/box🤔picture???
Teebie   100 µW
100 µW
Post by Teebie » Jan 16 2021 6:32am
Despite this, hopefully someone else out there with an older 2015 Electric⚡️Series #1 can successfully pickup where I left off (since I unfortunately don’t have any equipment, or know how to go any🏳️further), or even post their successful Series #1 &/or #2 upgrade to the eBike conversion kits, which I might have to now seriously consider...🤔💭🏁👍🏻
