Yep..Another VESC Based Ebike Controller 150V 200AMP
mystamo   10 mW
Post by mystamo » Jul 15 2020 6:10am
Hey all,
Been a hot heavy min since I've been on here.
2020 has been a complete nightmare for me. I lost my daughter River to a heart defect at 2.5mo old. She was a real fighter having had open heart surgery at day 5. She was born with TGA a disease where AORTA and PULMONARY arteries are switched..Aint that some shit? Congenital heart disease is a lot more common than you think 1/100 new born kids have a defect of some sort. Needless to say the whole ordeal has been a nightmare for my wife and I.
I've been working from home with the whole covid thing and have been doing a bit of biking with the wife so I had my ebike back out. Did a bit of research on speed controllers since I had left off and BOY! was I surprised...
I discovered VESC (I know..welcome to earth Mo)
I did a bit more research and found some decent designs. One in particular by Gelp on the Vesc group. He calls his vesc BESC which can do 150V at 200AMPS. I also saw a design called cheap FOCer. Loved the name and more simple design vs ben's VESC.
Fast forward a week or two and you have my new PCB and design . Done after BESC, VESC, FOCer and Axiom. A modular, cheap, small, low part count, high power, controller.
It will be a two part controller with power stage and control separate. I am done the control section send the boards out. The idea is to have a control section I can stick down onto any level power board. This is like the axiom just with way less parts. More simple if you will. Doing the power section now. Will add details as I go. I will be using ASC series hall sensors to measure current like the besc. But I'll use different drivers and fets.
Here is a sneak peak. Grandpa did it in Eagle..
amberwolf   100 GW
Re: Yep..Another VESC Based Ebike Controller 150V 200AMP
Post by amberwolf » Jul 15 2020 2:11pm
When you get to the power stage, you might look at ZombieSS's recent thread:
viewtopic.php?f=30&t=106688
mystamo   10 mW
Post by mystamo » Jul 27 2020 5:33pm
Got my PCB's from JLC and got my components on there. Just a few to solder on for the ADC inputs but so far everything on the board is checking out ok.
Got the board bootloaded and VESC firmware flashed. Actively using VESC tool and all I/Os I can currently test seem ok. Including the Servo PPM input.
Now I move on to the drive board.
Pic of REV 1. I've already sent in Rev 2 for certain things I didn't like (Font sizes via placements). As well as including the fact that it is a VESC based controller.
Mo
steveo   1 MW
Post by steveo » Jul 28 2020 8:05pm
Wow nicely done !
Repair Thread
http://endless-sphere.com/forums/viewto ... =3&t=27170
Hub Monster bike ~ 24s7p A123 15.4ah/18kv Six Phase Motor/Dual Max-E Adapttos/32kw~42.91Hp/Est 140LBS
X6 Kmx Trike ~ 24s4p 20ah/X6 MHM 602/Infinion EB324 IRFB 4110/20Kw~26.82Hp/Est 120LBS ~SOLD~
Lightening rods bike ~ 18s2p 10ah/1500w Inrunner/Infinion EB312 IRFB4110/2KW~2.68hp/Est 60LBS
EV Outboard ~ 12s8p 40ah/5KW GM Inrunner/Infinion EB324 IRFB 4110/18Hp Evinrude Drive/Est 100lbs
http://www.youtube.com/user/trdfreak03
mystamo   10 mW
Post by mystamo » Aug 01 2020 8:57pm
Hey All,
Finished with the drive part of my design today. DAMN, it took a long time to finish this and it was a total $%# to route.
I've opted to just go with a smaller 6 fet power stage right now TO-220 Package . I'll upgrade the drive board design once I validate the design and put some beefier more expensive fets in there.
Pic of the JLC Render as I send out the board for FAB.
Mo
PCB Drive.jpg (220.56 KiB) Viewed 71 times
