Embrown117 said:
Thanks for the reply, I'm actually farther along in this process than my post revealed, I know what I want and have most of the parts picked out already, I just need to know if I'm forgetting anything that new builders tend to overlook other than simply the motor, controller, battery, throttle and battery monitor. I probably should have made this post when I had all the parts picked out haha
Ok. Something to be aware of is that picking out the parts you already list is dependent on the stuff in those questions I listed. If you've already gone thru the process of ensuring you've picked the right parts to satisfy what you need the bike to do for you, then you're set for those. But if you have just picked them based on some other criteria, it may not end up doing what you want. We've seen plenty of new builds that didn't go thru the process that didnt' work as desired.
Even if you've already done the process to pick out the things you already list, it does still matter for us to know the answers to some of those questions as to what other things you will need. Since we don't know what you already have (or plan to get, or how you'll use it), there's stuff we won't know to list that might go with those specific items, or might be stuff you could use a specific version of if we knew what the application was. For example, there's many variants of some things, like volt/etc meters, throttles, torque arms, etc., and which one to recommend varies greatly depending on the purpose of the bike, what you want it to do, how you'll use it, what system you'll be using (controller/motor/etc), and so on.
With the info provided, all I can give is basic suggestions, and you'll have to figure out what to actually use for them. Some have much better options / versions available for certain applications. I may have listed stuff you already have or have thought about.
Heatshrink
Insulating tape
Cable ties
Cable sleeving
Electronic braking engagment device
Throttle control device
Torque arms
Connectors
Watt/Voltmeter
Programming system
Charger
BMS
Chain/belt/sprockets (depending on motor/drive type)
Wiring diagram(s)
Fire prevention/circuit interrupter
Tools and test equipment, including crimpers, soldering tools, screwdrivers, wrenches, "ebike testers", etc., and whatever specific ones your motor/etc system will require for installation and maintenance (which may not be standard tool types, depending on what you're installing).
I've probably forgotten stuff; if I think of anything else I'll edit it onto the end of the list above as I remember it.
If you want lighting, I recommend this thread as a good starting point:
https://endless-sphere.com/forums/viewtopic.php?t=75171
whether you use what he did or not, how he did it is very useful.
My SB Cruiser thread also has stuff about lighting options, anything from LED strips to LED motorcycle lighting to car headlights to LED "trailer lights", though it is not organized and is scattered throughout the long thread. :/
