Raphael303
- Joined
- May 31, 2016
- Messages
- 38
Hi
I have an Erider Torque Sensor and a Phaserunner.
I have the problem, that when pedaling, on increasing pedal force the human watts are shown negative and the bike behaves weirdly. The eRider Torque sensor outputs a proper torque signal from 1.5 to 3ish volts, according to pressure on the pedal. Cadence however is a little erratic, drops to zero sometimes. fwd is set to 5v. Cadence is shown positive.
CA3 setting is torque sensor set to custom, 1-wire, 18 poles, 70Nm per Volt, 5V = fwd. Zero Torque routine done.
I contacted grin and Justin wrote to me, "we have seen some cases where it(erider) is actually susceptible to EMI noise of the motor controller and the output voltage drops to 0V for some periods of time."
When I disconnected the motor cable and the human watts then are shown positive only. I have then made sure that the two cables (sensor/motor) do not go in parallel. However they are within 3cm of each other for a moment in the lowest part of the bike. Apart from that the sensor wire goes along the downtube, while the PR and motorcable are on the top-tube. Having the two cables wired apart did not change the problem at all.
Note: I have a 72v Battery (84v full charge) and I use the voltage divider trick to show the correct voltage on the CA3. The CA3 and all other devices get 12V from a DCDC converter, which in theory could have isolated ground, but I bridged ground of course. The DC-DC converter is a Tracopower TEN 20-7212WIR ; 43V-160V to 12V.
Unfortunately Justin hasn't written back to me for about a week now, so I hope somebody here has an idea how to solve this interference problem.
