I'm wiring a brand new controller and motor, everything seems to work ok with no error code.
However, when I try to give it throttle the wheel just moves a few degrees.
When I crank the pedals and then give it throttle it spins, poorly, it vibrates and halts randomly.
I tried to switch around the hall sensor signal wires but it doesn't change much.
Any help is much appreciated.
