Cracking noise under hard acceleration
chronosgarage   10 W
Post by chronosgarage » Nov 26 2020 8:47pm
I’m using qs 205 hub motor 2000w 72v with votol em100 controller. The motor run fine, but on no load when it’s under hard acceleration or deceleration it makes a one cracking noise. I’ve tried to spin to see whether the hub is rubbing, and the hub have nothing rubbing against it.
Any idea what cause the problem
Any help is appreciated...
neptronix   100 GW
Re: Cracking noise under hard acceleration
Post by neptronix » Nov 26 2020 9:20pm
Ya know, cracked chainstays tend to do that.. in those conditions.. you may want to look the rear of the frame over.. especially if you have a dual suspension bike.
chronosgarage   10 W
Post by chronosgarage » Nov 26 2020 10:20pm
neptronix wrote:
Nov 26 2020 9:20pm
The bike do not have any chain. It’s a hub motor. I’ll will recheck And tighten the bolt and the torque arm. Thank u for you reply.
BDamari   10 W
Post by BDamari » Nov 27 2020 11:42am
My friend, chainstay is the bottom half of the swingarm on bicycles, maybe you have crack or damage there?
chronosgarage   10 W
Post by chronosgarage » Nov 30 2020 8:20am
Here is the video of the noise.
https://youtu.be/kAzIKoGF0uw
