Trio Cargo e-bike mid drive
Hi
I have a regular Trio Cargo bike (like first pic below, but white and with a 3 speeds gear hub). I would like to add a Bafang BBS02 on it, but like you can see, the bottom bracket is circled by aluminum tubes.
I find a 3D model online of the Bafang motor. I don't know if it's accurate, but if yes, the motor don't fit at any place (pic-2-3-4).
I know some cargo bike have this motor like Larry vs. Harry Bullitt, but is some one know if it can fit on a Trio Cargo?
If no, is someone know if the bafang motor can be modify a bit to help the fit?
As battery I plan to try to build a 52V 15Ah battery out of a 22V 45Ah battery module from a gen1 Chevy Volt.
So I will have to cut busbars and separate the groups of 3P cells.
Seem like a bit of trouble, but hey, this battery is almost free and super powerful!
- Attachments
- Trio cargo.JPG (28.43 KiB) Viewed 534 times
- bafang trio-1.JPG (52.65 KiB) Viewed 534 times
- bafang trio-2.JPG (50.59 KiB) Viewed 534 times
- bafang trio-3.JPG (41.79 KiB) Viewed 534 times
Re: Trio Cargo e-bike mid drive
Humm! After looking more and more at bafang pictures it seem like this motor will not fit in my frame except if I do important modifications to aluminum tube.
What about the compact TONGSHENG TSDZ2 for a cargo bike?
This motor is quite small. I don't find 3D model, but it look like I will only need to shave a bit of aluminum tube to fit it (red line on pic).
The big downside for me with this motor is the lower power and the fact it can't work with a 14S battery. I can build 12S battery, but I would like to have a 14S batt to match the voltage of other stuff I use.
Any advice?
Any advice?
- Attachments
- TONGSHENG TSDZ2.jpg (194.27 KiB) Viewed 475 times
use different bike
and bbshd
and bbshd
In 2013 an ad appears on Russia social networks: Интернет-операторы хотели! Работа в шикарном офисе в Ольгино !!!, зарплата 25960 рублей в месяц
- amberwolf 100 GW
- Location: Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Arm, Milky Way, Local Group
- Contact:
I'd venture that your best (meaning, easiest to install without modifying the trike) option to be able to use a middrive that goes thru your gears, on that trike, is to setup a StokeMonkey style drive in the frame in front of your cranks, which drives the left crank (you'd replace yours with a stoker left crank from a tandem), and thus can use all the gears of the trike.
Grin Tech http://ebikes.ca may still have some of their SM stuff in stock, but I don't think they have any complete systems left.
https://ebikes.ca/shop/electric-bicycle ... parts.html
"if it ain't broke, improve it till it is"----Dog-Hauler Cargo eTrike SB Cruiser----The HI-Lebowski: a Lebowski SMD brain running a zombified Honda IMA Inverter: a HOW-TO guide----Cargo eBike CrazyBike2----General Blog
[/quote]
In similar case, a hub motor with external controller and many wires seem an easier way to go.
Really, I'm looking at a 3D model of the TSDZ2 to see if it can pass on the frame if I cut it a bit like it seem to work with the BBS02 (see pics) and know more about the rear fixation bolt.
Or, any advice to use or not use the TSDZ2 on a cargo bike. We prefer the torque sensor of this motor, but the BBS02 is higher power and 14S compatible, so I hesitate between both.
Well... Strange how like some people show their high intelligence in public.
Right. Not a bad idea, but it remove the fact that a mid drive is nicely design with integrated controller, few wires and so.
- Attachments
- BBS02 with frame mod.JPG (107.45 KiB) Viewed 415 times
- TONGSHENG TSDZ2 3d.JPG (44.71 KiB) Viewed 415 times
After looking more and more at the tsdz2, it seem the BB and the motor are really close together.
For the BBS02 I found 13mm between BB output and motor (pic) or 29.5mm between BB center and motor.
Do anybody have those dimensions for the tsdz2 motor (or one of the red arrow)? I'm fear those dimensions are smaller compare to the BBS02.
- Attachments
- BBS02 motor gap.JPG (48.93 KiB) Viewed 401 times
- TONGSHENG TSDZ2 distance.JPG (144.63 KiB) Viewed 401 times
- amberwolf 100 GW
- Contact:
The SM style drive is a little less "compact", and more DIY, but it also gives you the option to customize any part of it you want, which is difficult or impossible with the single-unit middrives.
FWIW, a hubmotor in the wheel has several disadvantages (though some advantages), including making the wheel weaker, being unable to gear the motor up or down for varying riding conditions / terrain (so you don't get the best performance, and it takes more power to do the same things that could be done with a middrive-thru-the-gears), and it's less easy to work on the wheel if you need to do tire/tube repairs roadside. A hubmotor also has a different axle than a regular wheel, and applies torque to the frame / dropouts which a regular wheel does not (though an IGH-hub wheel does, it's done thru a well-developed torque arm/etc that comes with and fits perfectly the IGH axle; the same isn't true of any of the common hubmotors--the torque arms are all separate and not made specifically for that exact axle, and axles do vary (though they shouldn't) even within the same brand/model.
I've done my own middrives, both successful and not, and my own hubmotor-driven bikes/trikes (successful and not), and for this type of application, I personally would now not put the motors in the wheels anymore (despite the simplicity of the setup, I've just had too many problems directly related to doing that). My new trike (design in progress) will be driving the wheels via chain(s) from the motor(s) one way or another, which makes the wheel itself separate, stronger, easier to deal with problems roadside, etc.
So, up to you, and depends on your specific needs and limitations which works better for you.
I don't know enough about either to know what it would take to fit them on that particular bike, but if you want a torque sensing BB, you *can* use one with the hubmotor-in-wheel drives. I am not sure that you could make one work with an SM style drive (because it passes power thru the BB and so would be positive feedback).Or, any advice to use or not use the TSDZ2 on a cargo bike. We prefer the torque sensor of this motor, but the BBS02 is higher power and 14S compatible, so I hesitate between both.
Don't mess with the TSDZ2; it's notoriously unreliable, and the crank spindle breaks off.
And so hard to get parts for when it goes down.
Are you actually planning on carrying cargo, and using it on a regular basis where reliability is important?
If so, I would really lean towards wheel motor. The extra loads in the chain and cassette will eat them up quickly. Most of my customers that got a mid drive are shocked by how fast they're going thru parts, and that's separate from the motor itself failing.
Where crank drive really shines is off road, where the centralized weight and light motor makes the handling better, like in jumps.
Plus you can use modern mountain bike stuff like thru axle, and change flats easier.
But for utility bike that keeps both wheels on the ground all the time, it's really hard to beat the simplicity and reliability of hub motor.
So much easier to find parts of there's a failure also, and if the chain somehow broke, you can still motor home, which can happen more with mid drive. You can also use regen braking, which you can't with mid.
Great looking bike btw!
That's why I converted my cargo bike from BBS02 to front hub motor. I haven't regretted it at all.Voltron wrote: ↑Dec 19 2020 2:22pmAre you actually planning on carrying cargo, and using it on a regular basis where reliability is important?
Holy crap!!!
I google: tsdz2 crank spindle breaks off
What a bad engineered shaft!
Thanks. I'm happy to learn this before ordering it. It can not be a dangerous problem for my cargo bike, but what about this motor on my mountain bike. Never ever with this shaft
Well, as I really dislike external controller and/or huge diameter hub motor, it seem the BBS02 is the only choice for my modest power and speed need.
Just before you totally go down the crank drive path, your exterior controller could be as small, powerful and cool looking as this... (Courtesy of the website sponsor Justin LE!)
If you run rear rack with side bags, that does a lot to hide a motor.Re: Trio Cargo e-bike mid drive
Dislike it if you want, but a separate controller is easier and cheaper if you need to replace it (or want to upgrade it). Your bike has a great low-key place to mount one, underneath the floor of the cargo bay.
If it were my bike? I'd use a front hub motor-- direct drive if I wanted to use it all the time, geared with a one-way clutch if I wanted to use it only sometimes. BBS02 is entertaining to ride, and with careful use of gears it gives performance out of proportion to its power. But it has many points of failure, and it chews through drivetrain parts like they're Girl Scout cookies. I think it's a good choice for a play bike but not so much for a work bike.
How much power are you looking to run? IGHs really can't take a lot of torque and a 3spd won't have that much range to let you meaningfully pedal at higher speed.
Worrying about an external controller while running a mashup of EV cells also seems at cross purposes.
What I dislike is not the external controllers, it's the large quantity of loose wires coming with. And to add crank detection, you have to a have more wires and stuff to integrate.
Mashup battery? Well, I don't see any problem with this clean and powerful Chevrolet Volt battery with only 2 wires. Especially after fit a cover over it.
I'm ok with 500-750w of extra power and a top speed of 30-35 kmh. It's a bike to move kids, food and some other stuff, not a bike to do delivery as job.
Few years ago I tried a 10 kW hub e-Bike and it's was a lot of fun, but it's not the kind of performance I'm looking for this cargo.
What are the suggestions for hub motor kit with PAS at the similar price than a BBS02?
Well, the only wires you have to connect to anything are throttle, battery, and motor. PAS if you want it. There are more stray cables than that dangling from BBS02/BBSHD and its harness, and they're all out in plain view rather than tucked away underneath.
I have three BBSHD's. I like them a lot. But I have also burned up three stock internal controllers and I do not ride hard at all. One of them was water ingress. I have also melted the internal Anderson connectors between the controllers and the motor. I'm unhappy with that design. It is also very unpleasant to put back together in that tight space. Next time one burns out, I will go with an external controller. I don't know if the controllers in the 02's are more reliable.
This may not be relevant but on my LWB recumbent, which is heavy and long like your Trio, I am very happy with the combo I have. I have an old cyclone 500w in-line middrive and a MAC 5t (fast winding) in the front wheel. The midrive, using the bike's gears, accelerates well from a standstill but I usually cruise at 25-30mph with the Mac, with the cyclone helping on the hills. I have also been very grateful for two different systems when one give out (usually a loose connection somewhere due to my cheezy DIYing.)
2013 DB Haanjo Commuter with BBSHD and Zzipper fairing
Marin Rift Zone FS with BBSHD
Kysmo "lab" bike with 350w hub motor
Ryan Vanguard recumbent LWB with a 36v Cyclone 350w middrive and a 56v MAC 5t in the front hub.
