Battery won't charge
Hi,
I connected the bms to the 14s battery and in output it shows 54 V. The cells charge is 3.89 on average. I connected the battery to the bike and the motor works, but when I try to charge the battery, it doesn't charge. The same battery charger works on other batteries.
What could it be?
Thanks and happy new year.
What could it be?
- Attachments
- 01.jpg (189.9 KiB) Viewed 208 times
- 02.jpg (179.51 KiB) Viewed 208 times
- 03.jpg (161.25 KiB) Viewed 208 times
Re: Battery won't charge
wheres the P-
30Q test viewtopic.php?f=14&t=108547
40T test viewtopic.php?f=14&t=106550
Sony VTC6 viewtopic.php?f=14&t=108661
mnke 26650 test viewtopic.php?f=14&t=107191
Battery magnets viewtopic.php?f=14&t=106190&hilit=magne ... 5#p1563730
My BMS has only B-, C-.
attach the schema I followed
- Attachments
- 04.jpg (151.54 KiB) Viewed 195 times
Probably the wrong bms
Does your charger show fully charged when plugged in?
If it does then the bms is not for18650 cells that charge to 4.2v
Check which bms you purchased
Jonno
Jonno
Modified EEB frame, 888 forks, 280mm DNM pit bike shock, QS273 40h V3 3.5t, Nucular Electronics 24F controller 300a, 92V @ 36ah 26650 cells, 300a BMS with bypass,
Hope V4 + Galfer 223mm discs + Variable regen braking.
Amongst other builds.
Are you sure it's not a 13S charger? 54V and change would be for a fully charged 13S battery.marcoredit wrote: ↑Jan 02 2021 4:29amHi,
What could it be?
my econo-e-bike https://endless-sphere.com/forums/viewt ... =6&t=97945
Do you have a link to the charger, or a pic of the label?
.......or test the output voltage of the charger.
BMS looks correct
Jonno
BMS looks correct
Jonno
what is the voltage of the charger
label isn't marked
use volt meter and measure
charger output not connected to battery
if 54v and change?
wrong charger
if 58v and change
something else wrong
label isn't marked
if 54v and change?
wrong charger
if 58v and change
In 2013 an ad appears on Russia social networks: Интернет-операторы хотели! Работа в шикарном офисе в Ольгино !!!, зарплата 25960 рублей в месяц
The charger output is 58.8V.
So something else is wrong. Maybe the 15 wires are wrong connected?
- Attachments
- 06.jpg (220.48 KiB) Viewed 167 times
I have the same single port model BMS on one of my packs and have had no issues with it.
You could try completely disconnecting it and reconnecting it. It looks like you have it wired correctly. If any of the balance wires were misconnected, you should not have output to run the motor.
It may be a defective BMS board.
So I'll try to check alla the wires again and then change the BMS.
Thank you
Thank you
many bms die easily
high power gets expensive
consider low power charge bms only
discharge directly off tabs
outdoor battery discharge
no bms usually safe enuf
controller lvc should match 14s
cheap ebay solution
10-20A 14s bms wired charge only
cheap ebay solution
Have you actually pulled the balance wire plug out, and checked the voltages at the terminals there, starting from one end of the plug? If you do, you really really want to have steady hands as they are pretty close together and easy to touch the meter probes together, which I find doesn't make a big spark at that voltage, but is just enough to deform the plastic plug body around the terminals from the heat.
If it's the really tiny style plug, I usually just stay on one end terminal, and go down the line writing down the totals, then calculating the individual group voltages after, so the probes aren't as near each other.
If it is even voltages at the plug, and totals the same as the voltage straight off the pack, then it's almost for sure a bad BMS
