In a certain parameter state, long press and hold at the same time + to Enter
the password setting interface,Short press to switch password digits.Short
press and to Modify current value.After the password is modified, long
press and hold at the same time + to exit the password setting interface to
the menu interface.Save the last set password at the same time(Note: You will need to
enter this password for the next boot). Long press again + to Exit the
settings interface to the normal interface. If you do not press, wait for 8 seconds to
automatically exit to the normal interface and save the parameters. 5、the operation of the alternate "3745" password
If you forget the password when you turn it on, enter the “3745” alternate
password, press and hold the button for 10 seconds to enter the normal interface.
