https://www.batteryclearinghouse.com/products/lot-of-144-cells-used-a123-anr26659m1b-lifep04-3-3v-2500mah-in-3-emc-packs
Edit: Sale is over, so price is now $140 ($47/ea) for three 364Wh 12s4p A123 ANR26659M1B LiFePO4 packs. There were coupon-code sales for $112 on Black Friday and $105 in early March, so maybe there will be more sales later in the year...
Let's share info in this thread. Here's what I've figured out:
* ANR26659M1B specs: https://www.batteryspace.com/prod-specs/6610.pdf
* These are grade-A cells (has stripes around the negative pole, and has more numbers than just "ANR26659M1B" printed on the wrapper).
https://www.thunderheartreviews.com/2018/08/lifepo4-a123-systems-anr26650m1b-grade.html
* The full plastic case is included, and it's perfectly-sized for a bicycle rear rack. (photo below)
* To open the case, you need a Torx T10 with a narrow 2-inch-log shaft (so Torx screwdriver/key will work, but not a Torx bit).
* The pack is from a Dell EMC, so these are probably backup batteries used in data centers, meaning they've probably had near-zero charge-discharge cycles so far.
* I bought three of these packs back in December, and have been using the first pack. It's working fine on my ebike. I rode 15 miles at full throttle (350W controller), including a couple big hills, only pedaling on the hills, and one of the P-groups hit 2.7V just a couple hundred yards before arriving back home.
* It comes with a BMS. Is it possible to reuse the BMS? I just removed mine, without attempting to charge through it, bypass it for bulk charging, or otherwise figure it out. The battery works fine without a BMS (photo below, just has beepers to prevent overdischarge, and a $4 CCCV buck converter for very slow charging from a laptop power supply), although I would like to add a BMS and a 42V charger.
* Daly 20A 12S 36V separate port LiFePO4 BMS is $14.45 (free shipping); common port is $16.91; 15A is $13.60.
https://www.aliexpress.com/item/32924207294.html
The 20A common port version is $9.90/ea (5pc minimum).
https://dalyelec.en.alibaba.com/product/62442139979-815280659/LiFepo4_bms_36V_12S_20A_60A_PCM_PCB_common_port_for_3_2V_LiNCM_battery_pack_18650_Lithion_Ion_Battery_Pack_protection_board.html
Is there a Daly BMS manual somewhere?
* So far, I haven't seen any need to disassemble the pack. I'm thinking it would only make sense to dissassemble a few below-par P-groups (not the whole pack), and only after identifying them by measuring each P-group's capacity.
*YouTube videos about this pack:
https://www.youtube.com/watch?v=l3-jM2bi-kY
https://www.youtube.com/watch?v=3jPYyGjWqck
