itsik
- Joined
- Mar 8, 2021
- Messages
- 19
hello!
i had been trying to get this controller to work with 2 motors i have of the same type ( revolt 120 pro)
the issue is that i cant find a hall sensor wiring combination that results in a smooth operation of the motor
i went according to the manual and used the hall test feature, half of the time it results in a fail and the second half it finds a combination that results in a none smooth spin
wired clunking noises at half thrutol while the rpms jumps around, gettery top end, and if you press the peddle quickly, wired electrical noises that i think means the motor and controller went out of sync
i attempted looking for the currect combenation myself, going thorow 36 diffrent hall and phase wires combenations but didnt find one that worked
i also played with the available kp parameter, it affects it but i can't seem to get it to be perfect
if i apply a load to the motor, the motor has some power, but no were near what is supposed to be
the motor and controller do not get hot, and the amp draw from that battery is about 50 amps tops, while the dc limit is set to 150 amps
i uploaded some vids showing the issues
https://youtu.be/kq3GvhGnFF8
https://youtu.be/KzbHwU6juq8
https://youtu.be/M4rLZ5_QPKk
https://youtu.be/N0Ii_4olRig
https://youtu.be/VJI3suWyGBA
https://youtu.be/obRZOTsZqXQ
https://youtu.be/OiLeEfZfKrI
I hope you guys can help me tune this issue out
thank you!
thank you!
