Shengyi hub motor clutch
Promille   100 mW
Post by Promille » May 02 2021 4:23am
Hi,
Does anyone know where to source clutch and gears for shengyi hub motors clutches and gears for bafang motors
can be found all over the internet but for shengyi cant seem to be found anywhere?
Clutch is 74mm wide and the hole for the axle is about 12mm and the nylon gears are 40mm,
the markings says WOK DLK074-60
Thanks in advance,
Daniel
neptronix   100 GW
Re: Shengyi hub motor clutch
Post by neptronix » May 24 2021 10:26pm
have you asked ebikes.ca?
My first major build: 1.6kW 8T MAC motor on a Trek 4500 MTB.
Monster MTB: Leafmotor 1500w @ 4kW on a Turner O2 full suspension.
The monster scooter: Heavy duty Cannondale semi recumbent - under construction.
Blue Dream: Maxaraya FS semi recumbent and high efficiency mid-drive - under construction.
qwerkus   10 kW
Post by qwerkus » May 25 2021 5:04am
Shengyi has an OK customer support. You can get parts directly from china.
