WXBULL controller wiring help***
akookie
GC , Australia
Hey I was wondering if anyone could help me. I've got a WXbull 2000w controller and the voltage says 48/ 60v /64 / 72v / 84v . Now is that controller ready to run 84volts.. or do I have to solder something on the PCB board. Because there is a spot on the board that has 60v / 64v / 72v / 80v. Can anyone help me.. I only noticed the numbers written on the pcb board as I was soldering up the shunt..
Cheers
That is for low voltage cutoff and such. Install jumper connecting your size battery.If you dont put a solder slug across it should act as if it is run by 48v. I have a 3kw controller by wx bull that has the same thing but it's common for most cheap Chinese controllers.
