mrjonsmithanonymous
- Joined
- Jun 19, 2021
- Messages
- 1
I'm attempting to install halls on an inrunner to be paired with an ASI BAC855. I feel reasonably confident about the installation itself. But I'm lost with all the different options available for hall sensors on Digikey. Open collector? PWM? Analog? Digital? Push/pull? Open drain? Should I be selecting halls with a narrow voltage supply range (e.g. 3.0-5.5v), or ones with a wider voltage supply range? Should the max current supply of my hall sensors exceed that of the controller (20mA max) or match it? I'm lost. Help!
