Fallingwater
- Joined
- Sep 19, 2020
- Messages
- 18
A friend has given me the titular bike with a dead battery. It runs on 24V, which might be fine for flat areas, but our city is anything but and the assist fades pretty quickly when going uphill.
Given that the battery is already gone, I thought of swapping out the controller for a 36V 500W one (like $35 on aliexpress) and wiring an external 36V battery in a bag.
My only worry is whether the motor can take it. I know from experience with e-scooters that hub motors are usually fairly overengineered and can take 50% overvoltage if you don't go nuts with the watts, and 500W-nominal should count as "not nuts" while enabling the bike to take uphills a lot better than it does now.
The motor says "DEC8R24V250W" followed by a long number which I take it to be a date/serial. I tried googling and only found a couple hits about the same bike, but no technical info on the motor itself. this thread mentions a "Hulong" company, while this one in a hungarian forum suggests it's made by Bafang.
