Jan-Erik-86
- Joined
- Jan 23, 2019
- Messages
- 110
Hi,
I have a generic 1000W hub motor with a 1500W KT controller (~3000W modded) and KT LCD3 display with a simple FT-21X finger throttle.
So while pulling my kid around on a sledge in the snow I eventually burned up the motor wire, causing multiple phase and hall wires to shot.
LCD gave different errors:
01: Throttle Abnormality
03: Motor Hall Signal Abnormality
06: Motor or controller has short circuit Abnormality
I replaced the motor wire, and tested the hall sensors, and they all appears to work fine (they receive a steady ~5V supply, and ~5V comes and goes normally on the signal wires when slowly rotating the wheel).
When i use the throttle, it sometimes shows up on the LCD that throttle is being used, and sometimes not. Motor also just sometimes spin for a split sec, but no speed shows up on LCD.
Thinking it might be a throttle problem, i attempted to use the walk assist function instead, and while it shows walk assist is activated, the wheel spins intermittent, and sometimes not at all (When it doesn't, it does however kick in intermittent again when i spin the wheel manually).
Edit: I also tried PAS, but that's not responding either, on either of the controllers.
I thought i must have fried the controller, so I then replaced the controller with a previously used KT controller, but the problem remains the same.
So then the question is, is it likely that the LCD3 and/or throttle could be broken, or could it still be a simple hall sensor issue (since it does not register speed, and it kicks in intermittentlywhen walk mode is activated and when spinning the wheel by hand)?
I've uploaded a video of the issue here: https://youtu.be/LQ7aSn9Ger8
