zachleedogg
- Joined
- Apr 4, 2021
- Messages
- 10
Hey Gang!
I created this post almost a year ago now, and I wanted to post an update! I am thankful to those who helped me in that thread, I was given some valuable insights that made this project possible.
Finished product first because I know you people want to look at stuff:
To summarize, I set out to built a powerful, yet minimalist ebike, with as few components as possible, and as few wires as possible.
I landed on the following components:
The catch is that I didn't want to use a throttle, or any bulky items such as a screen or cycle analyst. And while the cycle analyst did perform the functions I needed, it was too large for my needs.
So I set out to design my own "MicroAnalyst" board that would input cadence and torque and output a throttle signal. And so begins my tale.
I started out with a simple design that was inspired by this post. Basically it is a circuit board that takes power directly from the 48V pack, steps it down to 10V which is suitable for the ERider Sensor, and then steps down again to 5V for the Arduino (an ATTiny85). (the schematic below shows version 2 that includes shunt resistor and amplifier, I will get to that point soon.)
View attachment E-BIke_V2_Schematic.pdf
First I had to install the motor and battery onto the bike. The Magic Pie 5 Golden Motor is surprisingly good quality. I was very happy with the fit and finish of the wheel I purchased. Only down side is I wanted the all black version but it was not in stock. Anyway, the Magic Pie has the monstrosity of a cable harness coming out of it. So the fist thing I did what hack it all down to the minimum number of wires required. There was a small circuit board embedded inside the harness, I just cut it out and used only the wires I needed.
The only wires I really needed were Pwr, Gnd, and throttle. Though I did keep the original water proof connectors because they seemed nice, I still had to re-solder every wire in the bundle.
Here is what version 1 circuit board looked like (please excuse the terrible soldering job, these parts are tiny!!!):
So long story short, version 1 did not work exactly as I had planned. Basically, this version only has two inputs: cadence and torque. The output, throttle signal, is sent back to the Magic Pie. The problem, is that the Magic Pie uses only "speed control" as opposed to "torque control". This means that the throttle signal, from 0-5V (actually 1-4V) represents the speeds that the Magic Pie will try to achieve, and it will use whatever torque is required to achieve that speed. I had very difficult time writing an algorithm that would translate only cadence and torque into a speed command when what I really wanted was to be able to control torque. Think about it, as a human, we output power in Newtons or lbs, and when we put that force onto a pedal, it turns into Newton-meters or foot-lbs. Want we want is to feel the bike respond according to our own torque input. Soooo, I was not able to write a stable algorithm that resulted in an "intuitive" feel. I got pretty close using a PID controller, but with lack of feedback from the motor, it was impossible to get a stable result. And with switching gears while riding, the feel would change a lot based on the current gear.
Now I knew exactly what piece of the puzzle I was missing: feedback from the motor. But how do you get the torque of a motor that does not provide you with such a signal? Use a DC current shunt resistor to measure the current going into the motor. Welp this meant that I have to make a revision of the board to include the positive battery lead that was fed to the motor. So if you look at U4 and R2 in the schematic above, there is a 5micro-ohm shunt resistor and an amplifier that now feeds into the micro controller. And because current into a motor is proportional to the torque of the motor, we now have the feedback we need to close the loop on this controller.
So 9 months pass, the project sits for a while until I finally got the itch to work on the bike again, I ordered the new circuit boards and this time I ordered a solder-mask stencil so that I would have a nicer finished product. Basically you spread solder paste onto the pcb like a silk-screen shirt machine and then place your components and stick the thing in a toaster oven.
Spreading the paste:
Final product (yes the inductor is cracked, dropped this board on accident but I made three of them so this one I can fix at a later time):
Given that this project was not really my highest priority in life (I just became a Dad!) I didn't really put much thought into the form factor or mounting, I just made the darn thing as small as possible. Here is what it looks like with wires soldered to it. I used 0.1inch pitch male headers to connect the wire so that it would be reasonably easy to un-solder them if needed (note the hot glue used to ensure to stray wires make contact with anything).
Mounted to the bike:
Cover installed:
Connections made. I do want to clean this up in the future, but for now there are 3 connections, and easy to service. Maybe I'll just wrap them with cloth tape tight against the frame or something:
Now for the fun part. With the current shunt resistor installed, I was able to write a very simple control algorithm using a PID control scheme. I wrote a few routines that sample the cadence, torque, and DC current in the background, and added a few digital low-pass filters to help smooth out some of the readings. And the main algorithm is shown here:
The cadence is used to detect start-up conditions. Once the MINIMUM_PEDAL_RPMS are detected the cadence_factor becomes non-0 and if there is also torque detected, the torque_factor also becomes non-0. These two values are multiplied together to create the assist_factor, which grows from 0 up based on cadence and torque. The cadence caps out a MAXIMUM_PEDAL_RPMS so that once a certain cadence has been achieved, the algorithm relies 100% on torque alone. When the cadence dies back down, it brings the assist factor back down to 0. The PID controller will take the <Setpoint> and send modify the <Output> (throttle signal) until the <Input> matches the <Setpoint>. It took a little bit of "tuning" the PID parameters to get smooth response, but once I tried riding the bike for the first time, daaaaaaaaangggg, I was blown away. The start-up was super smooth and the bike felt like it was an extension of my body. The harder I pushed, the harder the bike pushed back. I felt like a superhero with super strength flying up the steepest hills in SF. No jerking, no stutters, just pure fun. There is still a little bit of tuning to do, but that is mostly playing with the low-pass filters of all the sensor inputs, and maybe a little more PID parameter tuning to really dial it in. The software and hardware designs can be found on my github page here.
Guys, I'm super stoked to ride this thing around. It blasts like I'm riding a motorcycle. I actually built this for my wife to ride so at some point I'll have to hand it over to her. Happy to answer questions, take criticism, or to see if there is any desire for others to use what I have built.
Thanks yall,
-Z
Cover installed:
Code:
/**********************************Assist Algorithm************************************************************************/
static void PAS_algorithm(){
// Convert the cadence assist Factor to a percentage (from 0-1).
double cadence_factor = mapf(cadence_RPM, MINIMUM_PEDAL_RPMS, MAXIMUM_PEDAL_RPMS, 0.0, 1.0);
// Convert the torque factor to a percentage (from 0-1).
double torque_factor = mapf(torque_NM, 0, MAX_TORQUE, 0.0, 1.0);
double assist_factor = cadence_factor*torque_factor;
// Create the setpoint as a proportion of torque to current.
Setpoint = CURRENT_SENSE_MAX_CURRENT*assist_factor;
// Input is always the instantaneous current sense value.
Input = current_sense_A;
//Write the duty from the PI loop.
analogWrite(throttle, Output);
Thanks yall,
-Z
