is it as simple as just adding a correct value resistor?
jimmyhackers 10 kW Joined May 11, 2015 Messages 600 May 20, 2022 #1 is it as simple as just adding a correct value resistor?
E-HP 10 GW Joined Nov 1, 2018 Messages 6,384 Location USA May 20, 2022 #2 jimmyhackers said: is it as simple as just adding a correct value resistor? Click to expand... Two in a voltage divider arrangement seems like it would work. You want a divider that divides the voltage by 13S/20S.
jimmyhackers 10 kW Joined May 11, 2015 Messages 600 May 21, 2022 #3 ah ingenious. or me dummy. probably both. i guess a voltage divider compared to a straight single resistor maintains a better "synergy" with the exsisting led "off/on" values.
