frk1206
- Joined
- Apr 22, 2022
- Messages
- 37
I’m building my battery using the copper / nickel sandwich method. I did the negative side wire solder like this which is kinda yucky:
Then I had a idea and did the positive side directly on copper. Way neater since I was able to do the solder prior to welding:
should I redo the negative one like this? Or are they both okay? Not going to draw more than 40-50amp continuous from the battery.
