highest A on a 9c motor
nuvola   10 mW
Post by nuvola » Nov 09 2009 6:24pm
Hi guys,
I've a RH 205 7x9 motor 48V (800W) working with his original 27A controller.
I'd like to upgrade from my 48V 27A controller to this one:
http://cgi.ebay.it/Infineon-Electric-Bi ... 4399e026d9
it's a 45A controller!!
does anyone has tried this high A on a 9c motor?
how much acceleration improve? (I think should become similar to 5305 until 40km/h(my acteual speed max)
I don't want to burn everything... :twisted:
battery it's ok (48V 60ah 1C-2C)
bike 1) 9C Rh205 28" Rear, controller 48V 27A with 51V 60ah battery, watt's up
bike 2) 5305 26" Rear, controller 72V 40A with 72V 15ah battery, CA
tostino   10 kW
Re: highest A on a 9c motor
Post by tostino » Nov 09 2009 7:51pm
I'm running a controller like that at 70a. The motor will not melt at only 45a. Even with my limit, it doesn't get all that hot.
nuvola   10 mW
Post by nuvola » Nov 10 2009 5:57am
70A? it's amazing!
how many km have you done with this A?
are you working at 48v?
how is changed speed and acceleration?
what about battery range, how many km are you able to do?
liveforphysics   100 GW
Post by liveforphysics » Nov 10 2009 7:30am
The member here named "Methods" hits the 9C with over 100amps during hard acceleration.
It's a matter of keeping your throttle duty cycle with in the heating limits of the motor. AKA, maybe 100amps for 10second to get up to speed, then cruise at light throttle to let the motor cool down a bit before hitting it with a lot of current again.
tostino   10 kW
Post by tostino » Nov 10 2009 6:18pm
In fact, the higher current limit has not affected my range what so ever. It is exactly the same.
My battery pack uses LiMn cells, and I have 14s (51v nominal) and 27 usable AH. Pack is good to 10c (konion cells limit).
I have put just about 1,000 miles on my bike so far in the past couple months, which would be about 1,600km.
I placed relays inside my motor for delta/wye switching for a higher top speed, and better low end torque.
Depending on how fast I go, my wh/mi changes. If I am going flat out, hitting my top speed of 45mph and averaging over 40mph, I average 38wh/mi. This gives me a range of 36 miles/charge.
If I keep the speed lower at around 25mph, I can average around 22wh/mile, and that increases my range to 63 miles/charge.
Acceleration is great, it's not as good as some others on the forum, with higher battery voltages, but what can ya do?! lol
Off the top of my head, i'd say I get to 40mph in between 6-8 seconds, and it takes a while (10+ seconds) to get from there to 44-45mph. I'll have to time it sometime soon.
steveo   1 MW
Post by steveo » Nov 10 2009 10:25pm
I've hit peaks of 160amp on my star/delta run !!!!
-steveo
Repair Thread
http://endless-sphere.com/forums/viewto ... =3&t=27170
Hub Monster bike ~ 24s7p A123 15.4ah/18kv Six Phase Motor/Dual Max-E Adapttos/32kw~42.91Hp/Est 140LBS
X6 Kmx Trike ~ 24s4p 20ah/X6 MHM 602/Infinion EB324 IRFB 4110/20Kw~26.82Hp/Est 120LBS ~SOLD~
Lightening rods bike ~ 18s2p 10ah/1500w Inrunner/Infinion EB312 IRFB4110/2KW~2.68hp/Est 60LBS
EV Outboard ~ 12s8p 40ah/5KW GM Inrunner/Infinion EB324 IRFB 4110/18Hp Evinrude Drive/Est 100lbs
http://www.youtube.com/user/trdfreak03
DerekG   100 W
Post by DerekG » Nov 11 2009 12:09am
Just reading this thread makes me jealous :-P Some day I have to get to converting my 22 amp controller into a 32 amp one.
Putting in relays for wye/delta also sounds incredibly cool, however, it's a bit over my head right now. I don' have the money to just buy another if I mess up so I have to be careful with what I have :-)
tostino   10 kW
Post by tostino » Nov 11 2009 1:15am
DerekG wrote:I don' have the money to just buy another if I mess up so I have to be careful with what I have :-)
I don't have the money either to replace a broken part instantly right now either, however, I feel pretty confident with my abilities to fix whatever problems may arise.
MattDog   1 W
1 W
Post by MattDog » Nov 11 2009 1:26am
...and we need videos of how to ride without smoking the box....because it is art
WalMart Gray Mongoose aluminum frame / Black steel fork 700c bike which had a rear rack pre-installed (~$119)
AmpedBikes (Nine Continent a.k.a. 9c) 500W front hub, & supplied Nine Continent (9c) 36v 22a controller
PingBattery 48v 10ah LifePo4 Array from Li himself @ http://www.pingbattery.com (not eBay)
tostino   10 kW
Post by tostino » Nov 11 2009 1:38am
http://www.endless-sphere.com/forums/vi ... 30#p208108
There ya go, it's not much, but the only videos i've got right now :p.
MattDog   1 W
1 W
Post by MattDog » Nov 11 2009 2:05am
man....you are SERIOUS!...I guess I had better get some head gear.
