Parker
Hi
Powering home from work today I suddenly lost power. This is bad as I'm not able to peddle normally. I had previously sent my motor to Earl of the Powerridestore to get a new free-hub and check the motor bearings. He gave me a great deal. It turned out the motor bearings were shot. He said he'd never seen anything like it. So he put in new bearings which stopped the squeaking I had posted about here before. There is still a problem with the free hub though as it does not screw into the motor. It's basically held on by the frame or a lock ring. It's very stiff to peddle and threatens to lock up. I put off calling or working on fixing this problem because I could motor to and from work easily without pedaling.
However that changed today. I should have have plenty of power to get home as I had been charging for 4 and half hours at work. When I lost power I noticed the Xlyte controller was still lit up but dimly. After I walked/coasted home I tried charge the batteries. This is an xlyte 36v sla 2.5amp charger. It just kept blinking green when usu. it stops when I charge it. I took off the battery pack and checked for lose connections. Nothing was very loose. I don't understand why the batteries won't charge or if that's the main or only problem.
There was a thunderstorm today. And it started raining just a little before I got to work. I don't think that affected anything but there's a possibility. also the power cut out when I was at work too. Maybe something happened there. But everything seemed fine and I made it for 4+ miles before anything happened. I also accidentally left the controller on while I was charging it today.
Ideas?
Ideas?
