Lyen
Hello Silver! Sorry to leave you in the dark for over 120 hours. I've been busy shipping things to many ES members here. But there is no excuse for me. I have made a thread here on how to wire it properly for you below so other members can benefit from it as well. Please let me know if you have any other questions. Thanks!
So here we go:
1. Determine the pin number & colors to the connector:
2. Add a diode (1N4001) to pin number 6 (The negative of the diode goes towards the wire. Look at the picture carefully. Also, add a little PVC head shrink heat tube is ideal not not really needed):
3. Solder a diode to the wire (Confirm the polarity):
4. Add heat shrink tube:
5. Short a resistor on R36:
6. Solder in the blue wire with diode to the SLA pad:
To be continue...
So here we go:
To be continue...
