I've seen where others have done it this way too. I just paralleled all three throttle wires together on my first experiment, and since it worked have always done it that way. So I guess either way works ok. Somebody did not parallel their batterys together, and the batteries tried to balance through the little throttle wires and components, which of course fried something.I just common the signal wire on the throttle to both controllers and only use the 5V and gnd from 1 of the controllers.
you should only use the +5V from one of the controllers to the common throttle. reason is that this is an output signal and is not designed to be an input. and these are not usually designed to handle a reverse current. if the +5V is higher on one of the controllers than the other this can feed back through the 5V regulator on the other destroying that regulator.
but this is a cautionary thing. just because it could happen, it does not mean that it will necesarrily happen. but in my mind why take the risk.
rick
Are you going to tell us how you did it then?CORBINFIBER said:you can control 3+ hub with one throttle
Is there a schematic somewhere?zombiess said:The Xie Chang based controllers many of us use do not share one throttle well. The solution is cheap, but you need basic electronics skill to build it. It's two NPN transistors setup in an emitter follower arrangement which act as a buffer. I implemented this same setup on my throttle interface and it works good to use 1 throttle on 2 controllers with no odd current sharing issues.
d8veh said:Is there a schematic somewhere?zombiess said:The Xie Chang based controllers many of us use do not share one throttle well. The solution is cheap, but you need basic electronics skill to build it. It's two NPN transistors setup in an emitter follower arrangement which act as a buffer. I implemented this same setup on my throttle interface and it works good to use 1 throttle on 2 controllers with no odd current sharing issues.
Does anyone know if the CA output can be split to two throttles, or batter still, three?
I use one CA per controller. KISS.d8veh said:Is there a schematic somewhere?zombiess said:The Xie Chang based controllers many of us use do not share one throttle well. The solution is cheap, but you need basic electronics skill to build it. It's two NPN transistors setup in an emitter follower arrangement which act as a buffer. I implemented this same setup on my throttle interface and it works good to use 1 throttle on 2 controllers with no odd current sharing issues.
I routed the single-wire throttle output of my CA V3 stand-alone directly (using a splitter cable) to the throttle inputs of 2 identical 6 FET cellman controllers that power two 350W MAC motors. I installed switches to independently turn each controller on or off. This configuration works well. I usually run the rear motor only - turning the front motor on just for hills.d8veh said:Is there a schematic somewhere?zombiess said:The Xie Chang based controllers many of us use do not share one throttle well. The solution is cheap, but you need basic electronics skill to build it. It's two NPN transistors setup in an emitter follower arrangement which act as a buffer. I implemented this same setup on my throttle interface and it works good to use 1 throttle on 2 controllers with no odd current sharing issues.
nieles said:d8veh said:Is there a schematic somewhere?zombiess said:The Xie Chang based controllers many of us use do not share one throttle well. The solution is cheap, but you need basic electronics skill to build it. It's two NPN transistors setup in an emitter follower arrangement which act as a buffer. I implemented this same setup on my throttle interface and it works good to use 1 throttle on 2 controllers with no odd current sharing issues.
what about a single supply op-amp as a voltage follower? only two parts needed. the opamp and a socket to solder the wires to.
any obvious flaws i am overlooking?
