Some do a trick where they undo the screws, then bang the opposite side axle end down on a block of wood to start the pull.
I prefer to use a thin wedge, like a knife I don't mind ruining to start the crack, then switch to three thin screwdrivers. Don't put the drivers too far in, and cut windings or something, just the tips. Once opened up far enough, a puller can be used, or prying with wider tools.
Slow and carefull is the thing I think. Don't remove the core from the motor unless you have to. You can lose a finger putting it back.
