Blowing 20 Amp fuses on a 500w Direct Drive Hub
bigchief   100 mW
Post by bigchief » Jul 09 2010 12:26pm
I just finished my new E-Bike; I'm using a 36v, 10amp rated (20amp peak) 10AH LiFePo4 battery with a 20 amp fuse, a 500 watt Direct Drive hub, and a controller of indeterminate wattage.
The setup works great and takes me to 20-25mph without pedaling; the only problem is if I floor the throttle at mid-speeds, I sometimes blow the 20 amp fuse. I biked five miles to work and blew 3 fuses, each time when near or at max throttle and about 15mph. Other than that it's working great. Where would I start in trying to figure out how to prevent the setup from not drawing over 20 amps?
rhitee05   10 kW
Re: Blowing 20 Amp fuses on a 500w Direct Drive Hub
Post by rhitee05 » Jul 09 2010 12:34pm
Does your controller have current limiting? Does the BMS on your LiFePO4 pack do current limiting? Preferably, the controller should be limiting the current, but BMS often includes a limiter to protect the batteries. Usually the BMS is a sharp cutoff, where the controller will just control the throttle to keep current within bounds.
From the small amount of info provided, it sounds like your battery pack is a poor match for the hub motor. Your pack is only rated to supply 360W, but your hub is rated for 500W (and they will frequently try to draw 2x rated under heavy load). You need to either find a way to implement strict current limiting in your controller or get more battery. Your batteries are at risk of dying a swift death with the current setup.
Do you have a cycle analyst, watts up, or similar meter that will let you measure the battery current draw?
Eric
Trek FX 7.3 hybrid - Cyclone 650W setup in process! Still...
TylerDurden   100 GW
Post by TylerDurden » Jul 09 2010 1:30pm
bigchief wrote:...and a controller of indeterminate wattage.
That would be the source of the problem.
The motor will take all you give it, until you have a controller to hold it back. Even if you block the throttle from full, a hill can still get you.
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
bigchief   100 mW
Post by bigchief » Jul 09 2010 1:36pm
rhitee05 wrote:Does your controller have current limiting? Does the BMS on your LiFePO4 pack do current limiting? Preferably, the controller should be limiting the current, but BMS often includes a limiter to protect the batteries. Usually the BMS is a sharp cutoff, where the controller will just control the throttle to keep current within bounds.
I don't have a Watts Up, I might invest in one.
My batteries actually do not have a BMS, they are 12 3.3v cells in series (resting voltage of about 40v in practice). There is a BMS in the battery charger only.
I'll try to figure out the model and stats of the controller to see what it's supposed to be pulling.
bigchief   100 mW
Post by bigchief » Jul 09 2010 2:10pm
Oh, I might have thought of something. People here talk about shunting (making a solder pool?) on a controller to draw more amps, right? Could I wick away solder from that area or use a small gauge wire or something to limit the current?
John in CR   100 GW
Post by John in CR » Jul 09 2010 2:41pm
bigchief wrote:Oh, I might have thought of something. People here talk about shunting (making a solder pool?) on a controller to draw more amps, right? Could I wick away solder from that area or use a small gauge wire or something to limit the current?
You'll need to look at what the shunt wire consists of. On a low power controller it may be only one. If there are 3, then removing one will reduce current by 1/3, and if 2 then removing 1 would reduce it by half. If there's only one, then you could file it thinner, which would be easier than finding a replacement. They're made of a special metal whose resistance changes very little as it gets hot, so you can't just replace it with any old wire.
dnmun   100 GW
Post by dnmun » Jul 09 2010 3:20pm
try a 40 A fuse.
bigchief   100 mW
Post by bigchief » Jul 09 2010 4:19pm
I attached a picture of the controller opened up. Is it these thingies here? There's markings for three of these jumpers, but only two are mounted. the one in front is bigger and has ridges along the top, and the second one is a smooth looking jumper and is shorter. So I should try filing down one of those, or eventually clipping one off if I still blow fuses?
Picture of shunts (I think)
TylerDurden   100 GW
Post by TylerDurden » Jul 09 2010 5:12pm
bigchief wrote:I attached a picture of the controller opened up. Is it these thingies here? There's markings for three of these jumpers, but only two are mounted. the one in front is bigger and has ridges along the top, and the second one is a smooth looking jumper and is shorter. So I should try filing down one of those, or eventually clipping one off if I still blow fuses?
You could unsolder one of the shunt legs and lift it free from the board.
When you ride, it should feel emasculated, but it probably won't blow fuses. You could then build up solder on the remaining shunt until it just blows a fuse, then shave the solder back to a "safe" amount.
Have a Nice Day,
TD
bigchief   100 mW
Post by bigchief » Jul 09 2010 5:25pm
Sounds good, I just de-soldered a leg and I'll give it a try. Thanks for the help!
mwkeefer   10 MW
Post by mwkeefer » Jul 09 2010 9:48pm
Just go for a 25A fuse and you should be fine, those are the EB709XC series (I can tell by the shunt adjustment) and are calibrated for 21A but they will pulse above to about 23/24 for a second (literally) on initial launch at WOT (wide open throttle) but will simmer down - on my CA I could see no more than 21.7A on the User Real time display of current but when I checked the Max Amps - it was 24.7 just too fast for me to see it happen...
25A should suffice, however... you could also try 30A if that fails... but if 30A pops, you have an issue!
I wouldn't worry about the literally "INSTANT" peaks (hey maybe a slow blow 20A would suffice) and a 2C LiFePo4 will not be damaged by the transient 22 + surges...
Where did the fuses come from, I've received fuses marked as 20A before which were proven to blow at 15 or 18 in some cases...
Sadly you can't reprogram that controller - the software is not available at this time so it's not possible anymore.
Hope it helps!
-Mike
Regards,
Mike
{My Rides]
2010 Dahon Jack - GNG v1 - LYEN 6FET - 20/40A - 18S2P10AH - Nom:66.6v,1332w
2004 Hard Rock Pro Disc - Recumpence ms eDrive v4 - Astro 3220 4T - 12S2P16AH - HV110 - Left Side Drive - Gearing: 38mph
Nominal Peak Power @ 60 seconds: 5328 watts - Maximum Power: 49.8v, 120A, 5872w
2010 Downtube 8FH - Stock GNG v1 Stock Controller - EB809XC - 12-16S
2012 Downtube Nova 7spd - Stock GNG v2 - 12S2P10AH - EB809 - 12S-16S - 20A/30A,Nom VCC: 44.4, 888w
dnmun   100 GW
Post by dnmun » Jul 09 2010 10:30pm
the reason that one shunt has the ripples in it is because they adjust the shunt value by crimping the shunt with dikes several times along the length in order to RAISE the resistance of that shunt which increases the overall resistance of the two or three in parallel. so the cuts from the dikes show that it was actually calibrated at manufacture.
mwkeefer   10 MW
Post by mwkeefer » Jul 09 2010 10:41pm
If u think a bit deeper about it, it was indeed calibrated at the factory but physically calibrated with minor tolerances which obviously aren't (never are) accounted for with software recalibration.
One fix would be to try wicking up some of the solder near the base of those shunts but I don't think it's an issue, they will peak a tad higher than rated but no longer than a second by default (block time)
-Mike
Regards,
Mike
{My Rides]
bigchief   100 mW
Post by bigchief » Jul 10 2010 12:21am
OK, so get a load of this: I completely desoldered the leg of the crimped shunt, leaving only the middle shunt in. I was expecting the bike to have it's speed and acceleration gimped. Turns out the bike is now performing *exactly* the same as when I had both shunts in, only without any blown fuses (and I've been flooring it for about an hour). I shudder to think of how many amps that must have been trying to draw if I could remove an entire shunt and still keep the same performance. I'm hitting a top speed of around 20mph, and it took me up a 15-degree incline without peddling, at a faster speed than my super-high torque Heinzmann could manage. This thing is amazing!
Thank you all for the help, especially TylerDurden who was right on the money.
