battery gauge wire
crimsonsnake0   10 W
battery gauge wire
Post by crimsonsnake0 » Aug 06 2010 9:01am
hi could anyone with the knowledge recommend the correct gauge wire for controller and wiring batterys ? looking at 72v 1500 watt 45amp controller whats suitable please ? 10 gauge car audio wire? will that take the volts amps ?regards to all ebikers
Ypedal   100 GW
Re: battery gauge wire
Post by Ypedal » Aug 06 2010 11:31am
12 gauge will do if the runs are short.... if you have to run long wires go for the 10 ! :wink:
ES site status page:
ambroseliao   100 kW
Post by ambroseliao » Aug 06 2010 11:49am
Here are a couple of links for battery gauge thickness versus current carrying capacity...
http://www.powerstream.com/Wire_Size.htm
http://en.wikipedia.org/wiki/American_wire_gauge
Or as YPedal says, use 12 AWG unless you have a long run, then use 10 AWG. :D
Ambrose
http://www.ebikes.ca/ is the best!
TidalForce M-750X, Tidalforce S-750 with Crystalyte HS3540, 1x TF iO-X Cruiser. E+ 1000W hybrid bike. ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. Bosch Fat Packs, 37V 10Ah LiPO pack. Turnigy Multistar batteries
My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
tostino   10 kW
Post by tostino » Aug 06 2010 4:00pm
I'm personally a fan of the biggest wire you can afford to run. I just moved my battery pack up to 8ga wire :)
texaspyro   100 kW
Post by texaspyro » Aug 07 2010 1:04pm
Be VERY wary in your choice of wire... particularly car audio wire. That industry is full of frauds and mis-speced specs. My testing of car audio wiring showed many "100% pure oxygen free copper" wires (even from big names) was not. Some was plated aluminum at 1.6 times the resistance of copper. Others were mystery metal with over 3 times the resistance of copper.
Some 4 gauge wire was maybe 10 gauge, surrounded by lots of (cheap) insulation. You might think that you bought 4 gauge, but you got 8 or 10 gauge in disguise. In the heavy gauge (0 - 8 gauge) material, the Scosche EFX Flux cables and Excelene welder cables tested very well.
Ypedal   100 GW
Post by Ypedal » Aug 07 2010 4:26pm
The best stuff i've use so far is the hobbyking.com silicone stuff ( supper soft, and crimps well.. )
http://www.hobbyking.com/hobbyking/stor ... (1mtr)_RED
texaspyro   100 kW
Post by texaspyro » Aug 07 2010 4:43pm
Ypedal wrote:The best stuff i've use so far is the hobbyking.com silicone stuff ( supper soft, and crimps well.. )
If you are curious about its actual quality/resistance/material/etc send me a foot or two and I'll test it on my HP3458A 8.5 digit meter with the Kelvin connections... I can resolve down to micro ohms.
Ypedal   100 GW
Post by Ypedal » Aug 07 2010 6:03pm
Cool !!.. shoot me a PM with a shipping address !.. i'll send a piece of 12 gauge and 10 !. 8)
Along with some zip cord :
http://www.powerwerx.com/wire-cable/red ... -cord.html
Stiffer, and not silicone coated, but i'm curious to know wich is better in terms of resistance !
johnnythefox   1 mW
Post by johnnythefox » Feb 26 2011 6:11pm
Anyone know the results of the test ?
Ypedal   100 GW
Post by Ypedal » Feb 26 2011 6:37pm
The result is the sad truth that i'm lazy procrastinating mofo... :oops: I still intend to follow thru with this... eventually lol..
Nathan P   1 µW
Post by Nathan P » May 04 2011 12:45pm
Did that test ever get run? :)
If you really need large cable at a good price, welding cable can be had cheap at most welding supply shops. I got 20 ft of 2 gauge for $40 IIRC. They had everything from 8 AWG to 0 AWG.
Nathan
