oatnet
Note that these instructions are unsanctiontioned and untested. This is where I think stuff should go, based on what I installed on 72/20v controllers. I could be completely wrong, so you are warned! IF YOU HAVE PHOTOS OF A PROFESSIONAL INSTALLATION PLEASE SHARE THEM!
We all love and worship the CycleAnalyst (Formerly known as the DrainBrain) sold here:
http://ebikes.ca/drainbrain.shtml
Justin (the mad genious creator of the CA) has supplied us with the picture below as an install guide for the 72v20a controller, and I've used that as a guide. I've done a handful of the 20a this is my first 40a.
http://ebikes.ca/drainbrain/Controller_%206-pin.jpg
1) unscrew the 4 nuts holding each end cover plate. These heads strip easily and are tight. I recommend a VERY VERY LIGHT tap with a hammer on each head to loosen them, and then break them free by hand before using a power driver.
2) Note the Forward/Reverse leads are in the way of removing the PCB. WIth the 72/20a version of the controller, you have to clip those leads because they are hard wired to the PCB. On this 72/40 version, the cable is plugged into slot s2 and can be removed. Wish I'd known that before I clipped the leads, but I never use the reverse feature anyway. Anyhow, disconnect the leads in your preferred manner.
3) Remove the 12 screws securing the bottom of the heat sink to the case. Here is a picture of the 1st 3 removed.
