Mounting Turnigy Watt Meter
dnmun   100 GW
Re: Mounting Turnigy Watt Meter
Post by dnmun » Apr 28 2014 1:45pm
the little shunts have a specific solder plane they have to be soldered onto so that the specified value is produced across the shunt. you will find it on the data sheet. the trimpots are there to adjust the inputs to the op amps that provide the amplification of the voltage across the shunt.
also i just checked on the most recent of my $13 cheapo wattmeters like in the picture and they do not have the trimpots like they used to.
Avitt   100 W
Post by Avitt » Apr 28 2014 1:55pm
I recently opened 2 x GT Power watt meters, and another 3 of the cheap blue aluminum ones, and none of them had trim pots.
made_in_the_alps_legacy   10 kW
Post by made_in_the_alps_legacy » Aug 20 2014 1:43am
thanks to the ones who dropped that seed, I did that mod' and I am very happy with it :
I will probably do it again for other projects :D
netwarri0r   1 mW
Post by netwarri0r » Sep 17 2014 12:08am
I have this GT power watt meter but the reading is not accurate, it's way off. It reads current at exactly 200ma less than the actual current. If i put a 1A load it reads 0.8 or what every load i put it reads exactly 200ma less. I have two multimeter which is accurate and it reads the current accurately. Is there a way to calibrate it? I opened the GT watt meter and there is no adjustment inside.
d8veh   100 GW
Post by d8veh » Sep 17 2014 3:29am
Have a look inside. IIRC there's a trim pot in there.
netwarri0r   1 mW
Post by netwarri0r » Sep 18 2014 6:56am
Already opened it and there is no trim pot.
sacko   10 kW
Post by sacko » Sep 18 2014 7:04am
I tried this a while ago.
I think the boards have changed :/
Post by made_in_the_alps_legacy » Sep 18 2014 9:05am
netwarri0r wrote:I have this GT power watt meter but the reading is not accurate, it's way off. .
it's maybe just a mix up between "precision" and "exactness" - above all, mine also have a .2 constant mismatch when comparing to separate multimeters measurement, ...and I am fine with that, (it's 0.4% unexact on a 50+ reading :lol: )
netwarri0r   1 mW
Post by netwarri0r » Sep 18 2014 7:18pm
This GT watt meter is useless for me because i am using it to test battery capacity. Maybe i should get the more expensive watt meter like watts up.
rmrf   10 W
Post by rmrf » Sep 20 2015 1:40pm
What about this cheapie? Looks like no modding required
http://www.ebay.com/itm/New-100V-100A-D ... 43c5b7c269
Has anyone bought smth like this?
jateureka   10 kW
Post by jateureka » Sep 20 2015 9:03pm
That volt amp meter requires a supply voltage between 4.5V and 30V.
Ok to run off your battery if using 24V nominal but if using a higher voltage battery pack then you'll need a step down voltage converter or a low voltage tap off your battery.
E-bikes: Bafang 8FUN; Mac; Ezee; FreeGo; Aprilia 7s LiPo; eLation V2; TerraTrike recumbent
E-motorbikes: ZEV 7100 LR scooter, 84V 60Ah LiFePO4.
ZERO 2011 S motorcycle, 51.8V 70Ah LiMno2, 2012 headlight, Kilovac EV-200 contactor
E-mower: EGO 56V mower & line trimmer
d8veh   100 GW
Post by d8veh » Sep 21 2015 4:54am
rmrf wrote:What about this cheapie? Looks like no modding required
It needs a low voltage power supply, which adds complications for use on an electric bicycle.
rmrf   10 W
Post by rmrf » Sep 21 2015 6:03am
Not necessary, it can work from the same battery if the voltage is lower than 30V (which is the case on many bicycles)
d8veh   100 GW
Post by d8veh » Sep 21 2015 5:31pm
rmrf wrote:....... if the voltage is lower than 30V (which is the case on many bicycles)
amberwolf   100 GW
Post by amberwolf » Sep 21 2015 8:55pm
Well, he's from Sweden; maybe the EU limitations enforced there prevent many from going to more than "24v" systems (which tend to be 28-29V hot off the charger, at most)?
For prebuilt bikes I imagine it's common, too, particularly in the EU.
But I'd guess that from the kits I've seen people building from on ES, even low-power noob stuff, 36v is more common, and 48v getting to be.
d8veh   100 GW
Post by d8veh » Sep 22 2015 3:10am
As far as I can see, 24v bikes hardly exist in Europe. They were more common before 2010, but now there's only a handful, normally offered by the big chain stores. I doubt that you'll find one in a normal electric bike shop.
amberwolf   100 GW
Post by amberwolf » Sep 22 2015 2:29pm
Ah. Then unless it's different in Sweden, I dunno.
Lurkin   100 kW
Post by Lurkin » Sep 23 2016 9:28am
Anyone know what these shunts are called to just purchase a handful of these shunts rather than the entire unit? tried searching through digikey but theres pages and pages under shunts... just want an inline shunt to sneak into a loom for a little project I'm working on...
ichiban   10 W
Post by ichiban » Dec 24 2018 11:16pm
Anyone still doing this mod now ?
ichiban   10 W
Post by ichiban » Dec 29 2018 12:16pm
I have been using a cheap GT Power watt meter (Turnigy clone) on my handle bar for quite sometime (5-6 months) before I came across this thread. As usual, I ran big wires 4 x 6sq.mm = 2 x forth and 2 back to and from the batt pack and the GT Power and that bothers me everytime I look at it.
I unpacked a new GT Power meter (same model) and did the mod today per Jereme's post but did not succeed. The watt meter showed correct voltage but amps, watts & wh always read 0. Just like the R shunt is 0 ohm and the meter cannot detect V drop across R shunt.
There are 3 wires, 24AWG from old USB cable and about 5-ft long ;
1 power from 14S5P batt pack + BMS (output taken from BMS) >> to the source -
1 in-between BMS & controller >> to load -
1 V+ (+14s) to where the red thick wire connected on the pcb of the GT Power
It looks like my solder is so poor with breaking copper wires from above picture, But in reality, it is much better than it looks. :wink:
These connections are corresponding, point to point, to how the R shunt connected on the GT Power's pcb. Just move the R shunt to a different location. "source-" and "load-" are per GT Power's front panel.
I soldered this removed R shunt in between 2 XT-90 connectors, back to back on the negative terminals. While the positive terminals were directly connected. Then connected the wires and ran it into the watt meter box with a small switch to power it ON/Off.
Below shown 2 meters measuring the same e-bike and from the same batt pack and at the same time.
+ The top meter is an old one I used for 5-6 months, connected to batt pack with thick wires.
+ The below meter is a new one I mod today. Vpack is OK but it does not read amps, watts & wh and the peak value as the top one.
+ Phone screen shows Vpack from bluetooth BMS, which is similar to the new watt meter's reading.
The 2 meters read a little differently but that is acceptable for now.
There is no trim pot to adjust anything in this GT Power model.
This mod is so simple that nothing could go wrong but it did.
Anyone experienced this and how to make it work ?
amberwolf   100 GW
Post by amberwolf » Dec 29 2018 11:05pm
ichiban wrote:
Dec 29 2018 12:16pm
*is* there a drop across the shunt? You should be able to measure it, though it will be very small.
If one of the sense wires to the TWM from teh shunt is broken inside, you would measure a drop across the shunt, but not at the meter. (and a continuity test would also fail).
If somehow the shunt is shorted (a bit of solder, etc) it might not have any drop across it.
It's also possible the op-amp that's used to amplify that voltage drop for the MCU is defective or damaged. Or has a solder issue from the factory, etc.
Note taht if you ahve the wires backwards from the shunt, the TWM won't read anythign since it only reads "forward" current. If it will read regen curretn flow from the controller (load) to the battery (source) now, then that's what's wrong.
It could also simply be a defective meter--you said it was new but had it ever been tested before modding?
ichiban   10 W
Post by ichiban » Dec 30 2018 2:20am
Thanks amberwolf. You are always my guardian angel ! :D :thumb:
Unfortunately, I've done some checking to confirm like what you suggested. There's some voltage across R Shunt sense pads up to the meter itself. Everything looks fine but the display still shows 0. I have not tested this GT meter before, just freshly opened the box and did the mod. So looks like my new meter is defective. I might hv to resolder the R shunt back to its box see what it will do.
I have to go outside for a while. I'll post some pictures tonight of what I hv done.
Thank you again.
ichiban   10 W
Post by ichiban » Dec 30 2018 11:36am
new GT Power R shunt mod 2018.12.30
Here are what I have done to find out where should the problem be at :
Both old and new (mod unit) GT Power meters connected in series, measuring the same current flow to the same controller & motor.
1) Check V across R shunt @ remote location : out from BMS & batt pack
- V shunt measured across new R shunt shown 2-8mV (Fluke 117 on mV range)
when thumb throttle press hard on PAS 9. New GT Power display showed 0 amp/w/wh.
I measured V across R shunt where arrows point.
Result (from Fluke 117) corresponds to our assumption : current flow results in V across R shunt.
That means R shunt is not damaged and works properly. I did not take picture here but
confirm that new GT Power showed 0 amp/watt/wh. It is hard to take picture by myself
doing that measurement.
2) Check V across original pads (on new GT Power pcb) where R shunt was (before
removed)
- V shunt measured shown 2-8mV (Fluke 117 on mV range) on PAS 9. Result :
Current is 2-8mV / 1 milliOhm = 2-8amps. Results looks OK. Accuracy might
be off quite a bit but it shows that the R shunt did sense current flow at the watt
meter pcb. So connecting wires should be OK but display show 0 amp/w/wh/peak.
From above measures, I think there is something wrong with the circuitry inside the
new GT Power. I might have to move the R shunt back to its original location to see
if the meter works properly. If not, that shows the meter is defective, either on arrival
or I damaged something during removal of that R shunt. If it works OK, I will have to
remove the R shunt back to the remote location again to see if it is OK this time. Lots
of works, is that worth it ?
Questions :
1) member dr_frost_dk posted Mar 08, 2014 re :
https://endless-sphere.com/forums/viewt ... 25#p863722
...i was locked at 137.??A like others complained about, but this was due to
connection missing at output - connection, there is a very small pad that needs to be
connected to the BIG pad, after that it worked as it should ...
Which "very small pad" is that ?
2) Probably I might order some new R shunt 1mOhm 1% to replace the original one
to see if it will do any good. My original GT Power (with big wires) still works Ok but
it is UGGGGLY. LOL
3) May be I will replace another set of bigger/new connecting wires to see if it will
work. Old one was about 5-ft long, 24awg from old usb cable.
Any comments ?
SpaceKaseJase   1 µW
Post by SpaceKaseJase » Dec 30 2018 7:53pm
Big coincadink! Just came across this thread and this last post was today, lol. Sorry, I have no advice, atm. I've just completed purchasing all items for upgrading my scooter. Last item I ordered was the G.T. Power watt meter. I hope you you or someone can find a way to sort your problem out. I'd like to do the remote shunt idea as well. More interested in volts, so shouldn't be a problem. Good luck, bro.
SpaceKaseJase   1 µW
Post by SpaceKaseJase » Dec 30 2018 11:26pm
Found this while browsing watt meter shunt mods. It's d8veh's post he linked to earlier in this thread. The link was broken, but this one works. I'd like to try this myself, but I'm using 12s lipos and 10 awg wire. He says to use 14 awg for the shunt. I'm wondering if that size wire can handle the current. Might try using the original shunt instead. Probably get the same issue you ran into.
https://www.pedelecs.co.uk/forum/thread ... ter.16869/
