What size nut fits on a Crystalyte x5304 front hub axle?
Floont   1 kW
Post by Floont » Oct 18 2010 9:08pm
:?: What size nut fits on a Crystalyte x5304 front hub axle? :?: And more importantly, where can I get one? :?:
While I was putting all my new ebike pieces and parts back together after my September 3rd wreck, I got a bit overzealous and accidentally cross-threaded one of my hub axle nuts. Fortunately, the axle threads were undamaged. I obviously have mechanically compromised the nut and do not want to reuse this damaged critical part. So I went on a trip to my many local so-called hardware stores and could not match that nut to anything. :(
So for the moment, I am left in limbo until I can locate a replacement nut. Any suggestions?
Thanks.
FA
Build 2: (present build): Rear x5304 on full suspension Mongoose, 127v 30s3p 10aH Turnigy Lipo, Lyen 24FET 100amp controller, CA2.2, 26" Hookworm front, 26" Crazy Bob rear, 203mm disc brakes, Airzound horn, twin Blaze 2 watt front lights - BURNED
All my posts on this site are licensed under the Creative Commons Attribution-Noncommercial-No Derivative Works 3.0 License
BLUESTREAK   1 kW
Re: What size nut fits on a Crystalyte x5304 front hub axle?
Post by BLUESTREAK » Oct 19 2010 12:55am
ELECTRICRIDER.COM. :)Hey FLOONT I live in TAMPA, give me a PM I will loan you one until you get a new one. COOPER :)
itselectric   1 kW
Post by itselectric » Oct 19 2010 10:35am
Floont wrote::?: What size nut fits on a Crystalyte x5304 front hub axle? :?: And more importantly, where can I get one? :?:
Thanks.
FA
5304 require 14mm fine thread nut, call your local hardware store start asking if they carry metric nut, if the don't carry metric, then forget asking the next question. If they have 14mm fine thread nut, ask them if the have nylon lock nut. This type of nut will prevent it become lose overtime. You can see the blue plastic around the nut in the following picture here.
Good Luck!
NutAndWasherSet [800x600].jpg (50.14 KiB) Viewed 3629 times
deardancer3   10 kW
Post by deardancer3 » Oct 19 2010 11:18am
Good Luck!
Try calling NAPA or a good Auto Parts store. Pep Boys is where I got mine.
d
Chain Drive Advocate
Floont   1 kW
Post by Floont » Oct 19 2010 8:40pm
OK... A 14mm fine thread nut.
Thanks! I'll go looking for one.
FA
EDIT: 14mm -1.50 pitch?
Floont   1 kW
Post by Floont » Oct 20 2010 6:56pm
It's amazing what you can write in a light color and no one can see it...
The last "edit" was a question to anyone who can answer it...
So is it true that the Crystalyte x5304 front hub axle nut is a 14mm -1.5 (14mm fine thread)?
FA
deardancer3   10 kW
Post by deardancer3 » Oct 20 2010 10:56pm
Metric nuts and bolts are not real pitch, put the distance between threads.
Soooo on the bolt, measure off 20 milimeteres and count the threads, Then divide by 20. If you have 20 threads, then it is a 1mm "pitch; if you have 13 then its 1.5mm; if 16 then it is 1.25mm.
d
Gregory   100 kW
Post by Gregory » Oct 20 2010 11:19pm
I recall years ago members here using Porsche wheel nuts that fit the X5 axle.
1) x5305 Hub Motor in a 24" Sun rim with 10G spokes, Kelly 72601 controller, 74V 10Ah Turnigy LiPo 20C Battery and CycleAnalyst
2) Mac 10T rear hub in a 700C "comfort bike" 15S 5Ah LiPo, stock 28A Xie Cheng controller
3) 38" Longboard, Turnigy 6374, CC Mamba XL2 ESC
itselectric   1 kW
Post by itselectric » Oct 21 2010 2:59am
Floont:
I am 99% sure it is 1.5 pitch, 14mm fine thread. I am getting old, can't hold enough memory in my head. When I purchased those nut from a special metric hardware store, I remember the clerk had mentioned something like 1.5 pitch. As far as I know, there are two type of common thread: fine or coarse.
Good luck!
Ken
Floont   1 kW
Post by Floont » Oct 21 2010 12:18pm
I just verified it with a tap from a warehouse near where I work. It is definitely a 14mm - 1.50 :!:
Thank you for all your help! :D
FA
rkosiorek   1 MW
Post by rkosiorek » Oct 21 2010 4:35pm
i agree it is M14-1.5. which is sort of a pain. BMX 14mm axles use a totaly incompatible even finer thread M14-1.0. lots of those nuts available at any LBS, but they don't fit.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
dogman dan   100 GW
Post by dogman dan » Oct 22 2010 6:17am
Ought to be able to find that in a lug nut.
John in CR   100 GW
Post by John in CR » Oct 22 2010 11:52am
rkosiorek wrote:i agree it is M14-1.5. which is sort of a pain. BMX 14mm axles use a totaly incompatible even finer thread M14-1.0. lots of those nuts available at any LBS, but they don't fit.
rick
Yeah, bike threads really suck with their non-standard stuff.
itselectric   1 kW
Post by itselectric » Oct 22 2010 3:02pm
dogman wrote:Ought to be able to find that in a lug nut.
We have suggested to Crystalyte to use lug nut on all their wheel.
Crystalyte had changed both 4x and 5x with lug nut back 2009. So it should have already come with it.
Floont   1 kW
Post by Floont » Oct 23 2010 11:47am
Bought two 14mm -1.50 nylock nuts from ElectricRider for $9 including first class shipping. :)
Tiberius   10 kW
Post by Tiberius » Oct 23 2010 3:01pm
itselectric wrote: I am 99% sure it is 1.5 pitch, 14mm fine thread. I am getting old, can't hold enough memory in my head. When I purchased those nut from a special metric hardware store, I remember the clerk had mentioned something like 1.5 pitch. As far as I know, there are two type of common thread: fine or coarse.
Good luck!
Ken
Be very careful. While Metric Coarse threads are standardised, you can't always be sure about Metric Fine. Unbelievable but true.
The problem is that there is a range of thread pitch possibilities, so while Coarse is the coarsest, the others are called things like Fine and Extra Fine, and not everyone agrees on which is which. Or, like many things, there is probably a clear official definition, but it only takes one or two suppliers to do something different for confusion to reign.
Best thing, once you get away from Coarse, is to quote the actual pitch. Floont says he's measured it as 14 x 1.5.
Nick
PS. To add a twist, so to speak, while we're supposed to be completely metric over here, I actually end up using a lot of imperial fasteners, and I usually get them sent over from the US.
Floont   1 kW
Post by Floont » Oct 23 2010 4:06pm
Tiberius wrote:...Be very careful. While Metric Coarse threads are standardised, you can't always be sure about Metric Fine. Unbelievable but true.
Best thing, once you get away from Coarse, is to quote the actual pitch. Floont says he's measured it as 14 x 1.5...
I fully agree. Stay away from the word definitions of coarse, fine and extra fine. When I went to that warehouse on Thursday to figure out what the "pitch" was, I notice a large variety of 14mm taps. They had taps for 14mm - 2.00, 14mm - 1.50, 14mm - 1.25, and 14mm - 1.00... four pitches total. The pitches appear to be standardized, but not the English word designation, with the exception of coarse, which everyone seems to agree is 14mm - 2.00.
And just to repeat myself, the Crystalyte x5304 front hub axle nut is exactly 14mm - 1.50.
FA
Floont   1 kW
Post by Floont » Oct 30 2010 8:39am
ElectricRider now sells Crystalyte x530x front hub axle 14mm - 1.50 Nylock nuts, obviating the need for a lock washer. I just received mine Thursday.
My only complaint about them is that they are regular thickness nuts with the additional thickness of the Nylock. If you have a few accessories mounted on the front axle (dual torque arms take a lot of axle space), there is very little axle thread left for the Nylock to hold on to. Other than getting Crystalyte to start making front hub axles longer (like that's going to happen), the only other option I can think of is to use 14mm - 1.50 Nylock jam nuts. Jam nuts have less thickness which would allow the Nylock portion of the nut to fully bind to the axle threads. I don't think anyone makes them, though.
FA
BLUESTREAK   1 kW
Post by BLUESTREAK » Oct 30 2010 10:57pm
I agree the cryastlyte axel needs to be at least 1/4in more on either side, like you said after a few extras on the axel it has nothing left. :mrgreen:
NorCalTuna   1 W
1 W
Post by NorCalTuna » Nov 04 2010 5:17am
A great nut for this app is the 14x1.5 lug nut from a chevy truck or suburban, cone side out obviously. Skip the nylock as it uses up thread that can be better used applying clamping force (the axle flats also require a very stiff nut to not deform and still hook up) and not chewing up threads and apply blue or green loctite instead (totally TOTALLY necessary step, after degreasing and drying both the axle and nuts!!!). The nylocks suck as they are soft metal and only 3/4 threaded, and the x5 needs tons of axle torque, completely insufficient for a overdriven x5.
There must be a dozen threads about this (I know I started one) but I put over a thousand miles on my bike having never touched the chevy nuts- I used a paint pen to mark "torqued o 'clock"- before I decided that bike was suicide and took it apart before it took me apart. I crashed HARD 4-5 times but the wheel never moved, upon disassembly inspection. Man, did that bike wheelie well.
If you PM me I can send you a pair from my stash if you cover shipping (they're sold in packs of 10)
Floont   1 kW
Post by Floont » Nov 04 2010 5:58am
NorCalTuna wrote:A great nut for this app is the 14x1.5 lug nut from a chevy truck or suburban... ...If you PM me I can send you a pair from my stash if you cover shipping (they're sold in packs of 10)
I PM'ed you. I'm interested because I'm not happy with the nut solution I have now. I am concerned they'll work their way loose.
Thanks.
FA
Floont   1 kW
Post by Floont » Dec 13 2010 11:14pm
Here's a link for 14mm x 1.5 pitch lugnuts that fit the Crystalyte x5 series axles perfectly:
http://www.amazon.com/Mr-Lugnut-30-2041 ... B001RGW6SA
Only $4.79 US.
FA
dazium   10 mW
Post by dazium » Dec 14 2010 11:07am
Hello all,
I just started my first build with the Crystalyte 5304 rear hub and have come across a few issues with the axle and nut's provided
1: the nuts are very soft and strip easily.
2: the axle would be better suited if it was not flat on both sides, less thread to grab on to
3: the battery brackets that attach to the axle should be center welded, not on the edge of the bracket, to balance out the weight of the batteries. The torsion of the batteries is too great for the nuts to hold on a smooth metal surface.
4: The wiring harness for the 72 v system is very short, it should be much longer to reach the batteries mounted in the brackets.
5: the connectors should be more robust, say maybe a 10-12 guage (yellow) spades.
I have made some calls around to find the nuts. they do not need to be from elecrtric rider or anyhing speciall. the best place to find them is Fastenal
the nuts come in bags of 5 or 10. and are fairly cheap ($10)
http://maps.google.ca/maps?f=q&source=s ... 998047&z=4
Ironhorse Warrior full suspension
modded LYEN controller
Crystalyte 5303
12s2p
custom build dash, with 6 hi int led, mounted underneath, Iphone 4 mount,rear led trailer light. toggle switch
max speed so far 58.7 km\h
Floont   1 kW
Post by Floont » Dec 14 2010 9:34pm
Thanks for the Fastenal recommendation. http://www.fastenal.com
In reviewing some of the products they sell; I found these:
There is a Disc-Lock nut for the 14mm Crystalyte axle threads called the M14-1.5 (see highlighted line):
I'd like to give these a try. They're $1.82 per nut. I also need to identify the rear axle nut size and get some for the rear, too. These nuts are used extensively on trucks and transports and resist vibration-induced loosening much better than traditional methods.
FA
dazium   10 mW
Post by dazium » Dec 28 2010 9:02pm
I just got my nuts in. They work well. Very hard steel. They actually cut the threads deeper on the axle. Which was perfect
Crystalyte 5303
12s2p
