80v to 100v dc dc converter needed
drewjet   10 kW
Post by drewjet » Oct 28 2010 3:19am
I am upping the voltage on my Suzuki to 85 volts and will need a new DC to DC Converter. My old Artysen only went to 75 volts so I need a new one, but am not having any luck. I need something that will go from say 60 volts to 100 volts input and 12v output. It needs to be isolated as I actually need 12 and 24 volts and I use 2 of them in series to get the 24V
Any ideas?
bigmoose   100 MW
Re: 80v to 100v dc dc converter needed
Post by bigmoose » Oct 28 2010 6:36am
I am trying to understand the high voltage (say 100 V) to xx V DC to DC converter usage in the field. Interesting that you are going to 24 volts final, may I ask what the load is? If you had a 100V to 24V converter would it still need to be isolated? The reason I ask is the lower the conversion ratio, the easier it is on the electronics.
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
liveforphysics   100 GW
Post by liveforphysics » Oct 28 2010 6:47am
Laptop power supply.
Commonly 80-250VAC or VDC input (even though they often only list 100vac-240vac), 14-20vdc output a 3-4-5-6amps depending on the type. High conversion efficiency, and often able to be waterproofed with just a careful smear of silicone over the seams and screw holes. Isolated. Often available on ebay for under $15-20usd shipped.
Parallel outputs if you require additional current.
Here is a 5Amp 15vdc model for $11 shipped:
http://cgi.ebay.com/New-Power-Supply-Ch ... 414a773865
drewjet   10 kW
Post by drewjet » Oct 28 2010 9:30am
I need 24 volts for my headlight, tail light, master relay, horn and also the controller. I need 12 volts for the turn signals. It was after I ordered new lipo at a higher voltage than I am currently at that I realized the need for a new DC DC converter. I know that I could tap off the first 3 series of 5 cell packs,(15S) and run my current converters from that, and I may till I get a good solution, but it will slightly imbalance the packs. It won't be a major problem as I balance charge with RC chargers every charge, but I would rather do it right.
Thanks LFP I will look into those, but I really need it to be a 12 volt outputs
Post by liveforphysics » Oct 28 2010 10:05am
They offer them in different voltages. Older lappys were 11-13vdc while they were running 3s lithium packs, then they moved to 4s, and now 5s is becoming common, so you see them in the 19-20-21v range often. Check around on fleabay.
John in CR   100 GW
Post by John in CR » Oct 28 2010 10:46am
As long as your current needs are low, those switching power supplies work great, and it's likely you have some sitting around the house already. I've tested the one I use all the way down to 60V dc input. Due to the low current output, you'll probably need one for 12V and one outputting 24V, though your lighting may need to be LEDs to have enough current.
John
jag   10 kW
Post by jag » Oct 28 2010 2:38pm
drewjet wrote:I need 24 volts for my headlight, tail light, master relay, horn and also the controller.
What a pain with all those different accessories at different voltages. I would change them for standard motorcycle gear. The 15V supply LFP linked will likely give 14-14.5V at the end of your wiring. That's what the charging voltage is on 12V car/mc systems anyway. If you go 12V and run car/mc stuff they will glow dimmer. Or if you;re concerend put a 0.7V silicone diode in series with the 15V output for 14.3V.
To get a small 12V supply, look in the halogen lighting department for switched supplies (the lightweight ones) in home stores. Note some pf these output 40-100kHz AC. I bought a couple of these for $10 each at Homedepot. First put a normal bridge rectifier on them, but that ran hot (due to high switching frequency). Then scavanged the HF schottky diodes from a couple of dead PC PSUs. This works fine, but as I said, on 12V sharp the "12V nominal" lighting glows a bit dim.
For more amps you can buy a Meanwell S350-13.5 for about $30-40 on ebay. These are not waterproof though.
MrKang   100 W
Post by MrKang » Oct 29 2010 12:58am
drewjet wrote: I need 12 volts for the turn signals.
isn't it easier to only replace your turn signals with led's with the right resisitor so the can run on 24V?
MrKang E-Scooter : 24V 750W Bosch Motor modified with YK-43 48V 1kW on 12S6P Lipo - top speed 44kmph
Xinling XTD800A : LYEN 4110 72V (modified for safe 100.8V with extra cooling) - 24S4P/100.8V 25Ah Turnigy + CA with Datalogger + SOUNDSYSTEM + USB power outlet + 78km top speed(120%)
MrKang Retro II : in progress.. ** 12FET MKII LYEN + 28S 20AH LifePO4 cells **
Project link [/color]: http://endless-sphere.com/forums/viewto ... 10&t=13442
amberwolf   100 GW
Post by amberwolf » Oct 29 2010 2:34am
Ditto on the laptop power supplies. Some of them I've seen at 5A output or higher. I think the 19V brick I use for boosting pack voltage to my CFLs on CrazyBike2 is 3A, and it's not even an inch thick by maybe 4" long and a couple inches wide. Could be made significantly smaller without the plastic casing. (probably could run a higher load, too, since it'd cool quicker).
auraslip   1.21 GW
1.21 GW
Post by auraslip » Feb 14 2011 7:45pm
Noob question, but do these need a pre-charge resistor? Or can I just use a normal spst 20 amp 125 VAC switch between the battery and the power supply?
THANKS TO EVERYONE HERE WHO TAUGHT ME ABOUT EBIKES. I'M IN YOUR DEBT.
I sell Ebike Brake levers and throttles with custom connectors crimped on! $10 shipped!
ES facebook group
r/ebikes ebikes on reddit
jag   10 kW
Post by jag » Feb 14 2011 10:11pm
auraslip wrote:Noob question, but do these need a pre-charge resistor? Or can I just use a normal spst 20 amp 125 VAC switch between the battery and the power supply?
Just a switch should be fine.
