R12 mod for high voltage regen
Hyena   100 GW
Post by Hyena » Dec 21 2010 5:34am
Hey guys,
I've put together a spreadsheet to make it easy to calculate what resistor changes are necessary to mod your controllers for regen at high voltage (above 75v). It's also handy for hardware changing the LVC and regen limits on non-programmable controllers (I also use it to run stock 36/48v 9C controllers on 15S lipo)
I didn't come up with this concept myself, information about how to do this has been posted in a few threads and knuckles posted the maths a while back and there's more info buried in one of the big infineon controller threads, but this way takes all the hard work out of it.
The pack voltage info I've included is for lipo (largely for my own convenience) but I'm sure you clever folks can put in your own values for lifepo4 or what ever else you're using
A few people have been asking me for this info lately so here it is
(maybe one of the mods can move this to the technical reference area ?)
Hyenas R12 Calc.xls
Hyena's R12 resistor calculator for high voltage regen
(39 KiB) Downloaded 806 times
www.HyenaElectricBikes.com
dbaker   100 kW
Re: R12 mod for high voltage regen
Post by dbaker » Dec 21 2010 9:19am
What is a 9C controller?
itchynackers   100 kW
Post by itchynackers » Dec 21 2010 9:26am
Awesome! Now I just need to find the original r12 value for my lyen 12fet.
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
Hyena   100 GW
Post by Hyena » Dec 22 2010 5:43am
dbaker wrote:What is a 9C controller?
Black infineon controllers as supplied by e-bike kit etc. I got a few bigger 12 fet units direct from 9C with the group order I placed.
itchynackers wrote:Awesome! Now I just need to find the original r12 value for my lyen 12fet.
Easily measured once you open the case to do the mod. I'm too lazy to open a 12 fet lyen I have here right at the moment but if I have cause to open it before you get around to doing yours I'll post up the resistance.
number1cruncher   1 kW
Post by number1cruncher » Dec 22 2010 9:59am
R12 on the 9FET e-bikekit controllers should be around 1200 Ohms. I think all the 846 boards use this same value. Double check though. Good luck!
Go to http://www.ebike.ca and buy stuff to support the rEVolution!
Electra Townie 700c Euro 8i - 20s2p Zippy LiPo - Rear 9c clone
Performance x201 - 18s2p - Rear 9c 8x8
All things lead to the path of least resistance.
"Political correctness is tyranny with manners." ~Charleton Heston
auraslip   1.21 GW
1.21 GW
Post by auraslip » Feb 14 2011 1:13am
Good stuff - just wanted to link to the article where knuckles talks about doing this. http://endless-sphere.com/forums/viewto ... 45#p127913
he says
The stock Infineon R12 value is 1200 ohm.
Is that true for all infineons you reckon?
In any case, thanks for making the spreadsheet :)
THANKS TO EVERYONE HERE WHO TAUGHT ME ABOUT EBIKES. I'M IN YOUR DEBT.
I sell Ebike Brake levers and throttles with custom connectors crimped on! $10 shipped!
ES facebook group
r/ebikes ebikes on reddit
Hyena   100 GW
Post by Hyena » Feb 14 2011 2:29am
Not all, no.
The 12 fet infineons from 9C I've used were 2200ohm
Kingfish   10 GW
Post by Kingfish » Apr 17 2011 1:03pm
Hyena,
I think you should post this in the Technical Reference Area: :)
Best, KF
* My 2WD Garden Wall
* Kinaye MotorSports
* Epics: Going to California: 2011 8)
NeilP   10 GW
Post by NeilP » Aug 03 2011 4:31am
Hyena, can you put a link back up to the calculator spreadsheet..it has gone missing.
Edit: found I had it and have re posted it below
Once the R12 has been modified...can the combined parallel resistance be measured directly across the resistors on the board? or do other components skew the result?
Lyen did my mod for me...and he tells me the overall resistance is now 400 Ohm and to use a 33 % change. From his e-mail
400ohm is the overall resistance value.
Program LVC = real (LVC + 2) x 0.75. For example, real LVC for 24S lipo is 67.2 (24 x 2.8, then program LVC = (67.2+2)x 0.75 = 51.9.
The maximum program regen voltage formula is (real regen x 1.33).
Problem is my controller has died within half a mile of use and it has only just arrived back from repair. It is not the motor, halls, or throttle. I just plugged the other Crystalyte controller back in and it all works fine again.
He has only just returned it after it failed the first time, within a week of building the bike.
it is an 18 FET Infineon Lyen edition 4110 65 amp controller EB218- AS - 1 revision board
I have taken the board out to check for dodgy components...and took an ohm meter to the R12 resistor...and the parallel resistor.
Reading from both R12 and additional resistor ( using three different meters for comparison) is 782 Ω
So can the parallel string be measured while fitted to the board?
:) Only Irish coffee provides in a glass all four essential food groups: alcohol, caffeine, sugar, and fat :)
NeilP   10 GW
Post by NeilP » Aug 03 2011 5:08am
I have found a copy of the xls sheet that I had already downloaded.
And now I am worried
IF the new R12 voltage can be measured while the resistors are in situ...then I think Lyen may have given me the wrong info with regard to the calculation of the new voltages after the mod
From what he told me, I used
Required HVC =83v..so 83 / 1.3333 = Program HVC of 62v
Required LVC =70v..so (70+2) * 0.75 = program LVC of 54v
but going by Hyenas spreadsheet
Looks like my figures are to high.IF the figure can be measured directly
So assuming I have over volted my controller because of too high a HVC figure...what have I damaged and what is the fix ...what components do I need to replace?
Screen shot 2011-08-03 at 11.02.59.png (82.26 KiB) Viewed 1547 times
grindz145   100 MW
Post by grindz145 » Aug 03 2011 7:15am
I couldn't manage to download it either, however this is super-useful.
NeilP   10 GW
Post by NeilP » Aug 03 2011 1:52pm
Hyenas R12 Calc.xls
(24.5 KiB) Downloaded 225 times
well since the original link is broken, and I found it on my machine, I''ll upload it again
I got my bike working again..the figures Lyen had given me were wrong. Maybe he assumed a different standard R12 resistor and did not actually measure it.
I e-mailed him as soon as I had the problem, and he has not got back yet, but he is always a while answering e-mails..I think he has a life other than checking e-mails every five minutes
My board is version EB218 AS -1
so if any one knows what the original R12 value is..and if it can me measured in circuit or not then I will be able to do some meaning calculations
SamTexas   100 MW
Post by SamTexas » Aug 03 2011 2:29pm
Hyena wrote:... to mod your controllers for regen at high voltage (above 75v)...
Why the 75V threshold? According the ebike.ca, the cutoff voltage for regen is 57V.
One other issue is that the controllers are designed to have a fixed 57V regen cutoff voltage. That means that regen will not work with a higher voltage battery pack unless you trick the controller into thinking everything is running at a lower voltage.
So in theory, this modification needs to be made if one is running 14s (58.8V) or above. Am I missing something?
NeilP   10 GW
Post by NeilP » Aug 03 2011 2:44pm
Not sure where you go the 75 volt from..I am aiming for 83 volt for my cutoff voltage for Regen
Exactly ..I am running 20 series..so at 4.15 per cell that is 83 volts.
I am actually wondering if it is an idea to set the regen voltage to something much higher, to give a good current back into the pack...OK so you would have to be careful when the pack is just off charge...but how about setting ( in my case) 90v or greater regen voltage. Unless I was going down a single continuous hill of many miles in length and braking constantly all the way down, even if the regen voltage was set to 100volts..the pack would never reach that or go above even the 83 volts...unless I started braking for a long period immediately after starting riding with a full pack
Post by number1cruncher » Aug 03 2011 2:45pm
There are two main types of controllers people use on ES: 846 and 116. The 846 has a lower (~57V) regen voltage allowance than the 116 (~75V). Lyen sells the 116s and E-bikekit.com used to sell the 846s.
NeilP   10 GW
Post by NeilP » Aug 03 2011 2:57pm
number1cruncher wrote: There are two main types of controllers people use on ES: 846 and 116. The 846 has a lower (~57V) regen voltage allowance than the 116 (~75V). Lyen sells the 116s and E-bikekit.com used to sell the 846s.
Have not seen those figures on the board at all.. the only reference I have seen on the board is the model number EB218 AS-1
Still, that does not answer my question of wether the overall parallel resistance can be measured on the board or not. that is what I need to know now, that and the original R12 value
EDIT..just had a revelation...846 and 116 refer to the MCU/..I'll have to pop the top off again and have look
Post by number1cruncher » Aug 03 2011 3:49pm
Yes, sorry, I meant to mention the numbers I was using referred to the MCU model. :oops:
I think your 792ohm is correct as you should be fine reading the resistors in circuit. The original value will be more difficult to find, since the values found around here could be for either MCU. I have a few 116 boards laying around my house, however they are 9 and 12 FETs. I'll see if I can come up with an average value when I get home in about an hour. Hopefully my family does not overwelm me when I walk in the door!
NeilP   10 GW
Post by NeilP » Aug 03 2011 3:58pm
If reading the resistance with it in series is OK, I could possibly unsolder one end of the new parallel resistor, and measure just that one, and the R12 on the board.
After two days I have only just got the controller fixed back in the bike. and taking it apart again, and doing some unsoldering,,just for he sake of it...just know something will go wrong..it is the usual way...tinker with something enough and soon enough you will F it up.
Back of board
Post by number1cruncher » Aug 03 2011 4:39pm
No need to disasemble the resistors I believe.
I just measured mine and they are all 1200ohms. Also the SMD resistor shows 122. I believe this translate to 1 for the first number, 2 for the second, followed by two 0s OR 1200.
Check your original R12 SMD. Does it show 122? If so, use 1200 to calculate your LVC! 8)
NeilP wrote:If reading the resistance with it in series is OK, I could possibly unsolder one end of the new parallel resistor, and measure just that one, and the R12 on the board.
Back of board
NeilP   10 GW
Post by NeilP » Aug 03 2011 4:48pm
I have not got a good enoguh picture to see tonight, so will pop it off tomorrow to get a closer look.
Looking at the last pic I posted...i suppose I could slice a window in the heat shrink of the added resistor, and check its colour code
miuan   10 kW
Post by miuan » Aug 04 2011 3:15am
Guys, have the 112 MCUs the same layout and resistance? Trying to make regen work on a cell_man's 12FET at 74V.
Hyena   100 GW
Post by Hyena » Aug 05 2011 7:25am
Sorry for the late reply guys, I've been away from the computer for 2 weeks.
NeilP wrote:So assuming I have over volted my controller because of too high a HVC figure...what have I damaged and what is the fix ...what components do I need to replace?
The HVC is only for the upper regen voltage really, so like you said unless you started out at the top of a hill on a full charge and regenned all the way down it's unlikely an improperly set HVC has taken your controller out. Infact if anything it would have only damaged your battery. Sounds like something else is wrong.
As for measuring the resistance, yep just put your ohm meter across the original R12 (or the new parallelled one) and read off the value.
Don't rely on the 1200 ohm default value in my calculator, that was just for one particular controller I was using.
You should always measure your R12 value before starting. That's the whole point of the calculator, to work out what additional resistor value you need.
Yep that'd probably be the quickest way to check the original R12 value. Just unsolder one leg of the new resistor then measure across the original SMD R12.
Ebikes.ca probably mentions 57v because the controllers and batteries they sell only go up to 48v (last time I checked anyway, apologies Justin if this isnt the case)
75v is fine for up to 18S lipo but for anything higher, ie 20S or 24S lipo (or the lifepo4 equivalent) you need to up the HVC.
miuan wrote:Guys, have the 112 MCUs the same layout and resistance? Trying to make regen work on a cell_man's 12FET at 74V.
Probably very similar if not identical but I'd double check to be sure. If the board layout is different using the diode/continuity beeper on your multimeter you can find one where else on the board the back of the R12 resistor goes
NeilP   10 GW
Post by NeilP » Aug 05 2011 9:37am
measured mine up, total new is Measueed at 782
Original is marrked 122. so 1200 and measures at 1160
The new resistor measures at 2390. so tha all figures correctly
just so I am 100 % sure I am using the spreadsheet correctly
The Original value figure is the one that goes in the program. and the calculated ' New Value' is the resultant figure that you actually get ? yes?
As an idea. is it ok to set the HVC higher than the final battery voltage. so I have 20 s that I charge to 4.15 per cell to 83 volts.,. So assuming I do not start massive braking with a fresh hot bsttery, ant harm in setting HVC at say 90 or 100 volt?
The pack is never going to reach that voltage, but it will give better braking early on in the discharge cycle
Post by number1cruncher » Aug 05 2011 1:19pm
NeilP wrote:As an idea. is it ok to set the HVC higher than the final battery voltage. so I have 20 s that I charge to 4.15 per cell to 83 volts.,. So assuming I do not start massive braking with a fresh hot bsttery, ant harm in setting HVC at say 90 or 100 volt?
Neil,
You lost me here. Are you still working on the LVC? If not, where are you setting an HVC?
NeilP   10 GW
Post by NeilP » Aug 05 2011 4:42pm
number1cruncher wrote: You lost me here. Are you still working on the LVC? If not, where are you setting an HVC?
bot LVC and HVC now sorted with regard to my R12 mod...but
i was wondering about setting the HVC higher than the pack voltage
. I have a 20 s pack...so 4.15/cell = 83 volts
So ideal HVC voltage is ...83 volts
But I was wondering if any harm can come in setting the HVC much higher..say 90 v or 100 v for the same 20s pack.
Although the system will try and push up to what ever limit you set...( the HVC limit) since the pack is below that voltage...hopefully 82 volts or less after a bit of riding. Setting the HVC higher may improve regen braking by ( and recharge current) by allowing a higher potential voltage.
