recumbent said:Looks to be 6" in dia. if the disc brake is any indicator.
Looks strangely familiar, is it a Puma type motor?
We want more info, like size, power and price, please.
Jozzer said:2kg heavier than a Puma, doesn't look THAT much like one ....
deecanio said:does look like the new puma to me?
gears look identical, by the way to all those who are having trouble getting hold of a puma and want one i spoke with Mark today on the phone and he is getting the new type motors that knoxie tested and controllers to go with around christmas time.
he hasn't had enough motors to meet demand up till now but new stock is arriving at teamhybrid very soon.
cheers
D
knoxie said:Hi
Right this is for sure from the BMC factory, the stator and rotor are the same as the Old School stamped BMC motors, there isnt nothing new there, I cant speak for the windings but the actual motor itself is from the BMC factory and not the Puma factory, its a little confusing however it isnt the same as Marks Puma motors, it also has the thin inner ring gear, this is ok at 37V but can cause wear when used at 48V and up, the BMX (New Puma) full keyed inner gear is much easier on the nylon gears and the Nylon gears are stronger in the new Puma.
Knoxie
knoxie said:Hi... it also has the thin inner ring gear, this is ok at 37V but can cause wear when used at 48V and up, the BMX (New Puma) full keyed inner gear is much easier on the nylon gears and the Nylon gears are stronger in the new Puma. Knoxie
knoxie said:The newer gears are stronger and the inner gear isn't pressed in to the side of the motor casing, rather it is keyed in to the shaft of the motor,
