Deepkimchi
So I took time for a test ride in my long johns (with jeans on top of course). Ambient about 32F/0C.
Got past the Base guards with no questions or strange looks, made sure to pedal.
On the flat it does about 33-35 kph no pedalling. Optimal speed is 20 kph with fake pedalling, anything faster you can't keep up and it looks weird.
Already had put about 5 miles on without recharging, started out this trip at 39.5 V and 3.6aH used. To work and back was 12 miles with a lot of hills.
Lowest V on the way to work was 36V, at work resting it bounced back to 38V.
Made it almost home, about 1/2 mile left to home before the controller started cutting it back (at about 28V). The voltage really dives at the end within a short time. I backed off the throttle, pedaled a little, then added slight throttle to keep going.
At home, the Cycleanalyst showed 37 V resting, 11aH used.
Now that I got my speedometer fixed, I'll reset next time and get the Wh/km info etc.
Started charging now at 11:30 Seoul time.
My biggest thrill was outside the Army Base, passing a big athletic type going up a steep hill in town. Made sure to pedal as realistically as I could.. :lol:
