will this charger work
diver
Sand hills S.C.
will this charger work for charging my 4 12 amp hour 12 volt sla battery's a little faster then my 2 amp charger. I want to buy a better and faster charger but there are so many. the soneil is on a recall so that is out. here is the link http://www.batterystuff.com/battery-chargers/48-volt/gel-cell/ICS4820.html I wish i knew more about EV so i could contribute info to help out people
thanks again
Butch
It damn well better, for that price. That seems overkill, but, like hunting squirrels with a scattergun; you can be confident it will get the job done.
As for contributing... your avatar is the most frightening I've seen. That in itself, is a good reason for you to play in our little sandbox.
For 37 lbs, guess you wont be taking that with you on the road.
I would go to soneils website and review their pages on hooking up their indentical chargers together in parallel and serially.
http://www.soneil.com/Completesets/Parallel%20&%20Serial%20Application.pdf
Then go shopping to buy two 4 amp 24v chargers.
back in the days when i stilled played with SLA i started with a single Soneil 2409 charger for my 24V packs. then when i went to 48V i just bought a second one and used it in series. worked like a champ. i bought them from some guy who advertises on the Yahoo Toronto EVA group.
i'd still be using them IF i still used SLA.
rick
wow you hurt my feelings, that is my wife on a good day. you ought to see her on a bad day. :mrgreen:
butch
