Arbiker501 said:
So where is the best place to get some cool fat tires?????
I'm running a compromise tire--Continental Travel Contacts (1.75 x 26"). They are slick in the middle and rated for 80 psi. I run them at 90 psi on smooth roads. I ordered them from UniversalCycles.com. They have "flat protection" belts, but I still get a lot of glass flats. In Portland, Oregon, ("The City That <hardly> Works") we have tons of bike lanes, but they never sweep them so they are good for emergency run-off room only. I'd get a flat plus per week, if I rode in them--even with frequent inspections to pick glass out of my tires. I find that big soft tires are actually more prone to flats than skinny road bike tires because they capture a lot of glass in the tread, which works into the tube, if not promptly removed. When I was a kid, I installed "tire scrapers" but I can't find them any longer. They make a bit of "whishing" noise, but knock the crap off your tires before it embeds. I might make a pair. I might also make some Kevlar tire inserts. The glass won't get past Kevlar that's impregnated with the right resin. I think many of the protective substrates manufactured into bike tires are simply not glued/held together sufficiently. Glass eventually works between the fibers, if the belt substrate isn't bound together.
Drunkskunk said:
dual speed motors are great. You can choose the type of motor you want to run for the conditions.
Yeah--but I've been considering another approach--two battery packs/chargers (probably LiFePo4) with a series/parallel supply selector switch. With a big DPDT switch, I could configure my power for speed (series) or range (parallel). If I want to get fancy, I could probably control it with a relay (contactor) and a remote handlebar mounted control switch. I could also leave one pack home for lighter weight, when I didn't need the speed or the range. Two smaller packs can be mounted in two locations on the bike for improved balance and utility.
I'm happy with my Yesa "48V" / 20Ah but I'm already dreaming of two 48 x 10Ah, which would deliver close to 110V in series mode but I think the 4110's might handle it, from what I've read. (http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=764&start=0&st=0&sk=t&sd=a)
Or, if you don't need that much power, two packs in this form factor would sure be sweet:
http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=2963&p=42118&hilit=Yesa#p42118
Another thing that Justin pointed out for me (and verified with the ebikes.ca simulator) is the X5 series hubs all perform pretty much the same, IF you adjust the voltage. For example, to make a 5304 go as fast as a 5303, increase the voltage. However, for any given load, power supply and mission, there ARE motor model choices to be made. I used The Gimp software to overlay simulator runs of the 5303, 5304, and 5305 for my setup. The '04 and '03 power and torque curves cross at about 28 mph. This implies that for loads resulting in speeds < 28 mph, the '04 will be faster. For loads resulting in speeds > 28 mph, the '03 will be faster. As it turns out, 28 mph is nearly level ground / zero wind for me. This mean that the '03 will be faster going downhill or with a tailwind and the '04 will be faster going uphill or with a headwind--all based on full throttle at my battery pack voltage, wheel size, etc.
Entertaining musings, I think!
-Cal
