Magura Hydraulic brake switch
NeilP
Post by NeilP » Nov 25, 2011 1:23 pm
Any one used one of these?
How easy are they to fit? I am assuming...drain brake fluid, cut line. clean up, install the switch and then bleed the system?
is that about it?
Also..how soon does the brake switch activate? does there have to be pressure on the brakes before the switch closes? or can you set it to come on before mechanical action starts?
one of these for those that do not know them
http://www.ebike-easy.com/products/Bicy ... rakes.html
:) Only Irish coffee provides in a glass all four essential food groups: alcohol, caffeine, sugar, and fat :)
Hugues
Re: Magura Hydraulic brake switch
Post by Hugues » Nov 25, 2011 1:27 pm
Hi Neil,
Got one, i'm satisfied with it.
Easy to install. It's the bleeding that gave me headache, but nothing to do with the switch. I finally solved that by buying the bleeding kit.
But the switch works great, as soon as you press, it activates the brake, the pads just barely start to contact the disk.
The first switch they sent me got a problem after a month, it stuck in open position, never got to understand the reason.
The vendor did not agree to pay me back, i did not insist much.
The one i have now for 2 months is looking good.
I've got a second one that i want to install on the front brake, the rational here is that if my rear hydraulic line fails, i loose both mechanical brake and engine brake, and i'm left with front brake only. So with the second switch i still have engine brake at least. A bit paranoid maybe.
Hugues
Switzerland
http://zvexx.com
NeilP
Post by NeilP » Nov 25, 2011 1:36 pm
OK, thanks that is good to hear. I think i will order 4 today
MattyCiii
Post by MattyCiii » Feb 28, 2012 6:57 am
NeilP,
What do you think of those switches? I'm about to buy a pair for my bike.
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 32mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 39mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike. Based on a common power module using a NuVinci left side freewheel.
Hugues
Post by Hugues » Feb 28, 2012 6:58 am
they work fine but not compatible with DOT 4 oil, only mineral oil,
I destroyed 2 :x
Hugues
Switzerland
http://zvexx.com
NeilP
Post by NeilP » Feb 28, 2012 9:07 am
They work just fine. They come on with almost no bite of the real brake , which is good
Dont use wrong brake fluid though or as Hugues found you will destroy them
MattyCiii
Post by MattyCiii » Feb 28, 2012 9:45 am
THANKS for the quick replies! Order placed.
mvly
Post by mvly » Feb 28, 2012 1:29 pm
Not sure if everyone knows about this, but:
http://www.ebay.com/itm/150740784320?ss ... 629wt_1413
Should be plug and play with some mods to the connectors
The only problem about this is if you want to use for regen, I usually press the rear brakes first. So this might take some getting use to.
d8veh
Post by d8veh » Feb 28, 2012 4:11 pm
mvly wrote:Not sure if everyone knows about this, but:
Good find.I just ordered one.
grindz145
1 GW
1 GW
Post by grindz145 » Feb 28, 2012 4:27 pm
That's a really nice solution. Really expensive though. Does anyone know of any brake levers/master cylinders that have brake switches integrated, and would work with magura bicycle brakes?
NeilP
Post by NeilP » Feb 28, 2012 4:43 pm
grindz145 wrote: Really expensive though.
I thought that was extremely cheap for a complete brake setup ...the fact that it also includes a brake switch as well makes it even more of a bargain as far as I can see.
grindz145
1 GW
1 GW
Post by grindz145 » Feb 28, 2012 4:47 pm
Maybe I'm mistaking this, but it looks like $35 for a single brake switch. That's pretty pricey. I don't see anything else but adapters included in the kit.
Edit: with the whole brake setup, it's not soo bad, but the aurigas aren't the best brakes in the world... by any means... I guess I'm just looking for something more universal
PSS: Didn't realize how old the beginning of the thread was...
NeilP
Post by NeilP » Feb 28, 2012 5:01 pm
Ah. OK, sorry I thought you were referring to the direct previous post .the complete kit on e-bay. Check out the previous post and e-bay link.
I should have read your post fully ..in the same way you should have read the previous posts a nd followed the link completely...it links to what you were asking for ..a complete kit. Not sure about working with a Magura brake though..not sure what exactly that is
grindz145 wrote: Does anyone know of any brake levers/master cylinders that have brake switches integrated, and would work with magura bicycle brakes?
grindz145
1 GW
1 GW
Post by grindz145 » Feb 28, 2012 5:04 pm
Definately not a chinese POS brake switch. Very solid. Looking for some options for my next build so it was very opportune timing.
mvly
Post by mvly » Feb 28, 2012 5:27 pm
Let us know how it goes.
mvly
Post by mvly » Feb 28, 2012 5:28 pm
I don't think it's complete in the sense, it including the rear. It states only Front, but that is all you need in most cases anyways.
Alan B
Post by Alan B » Feb 28, 2012 5:31 pm
Interesting brake with built in swtich. They should all have switches, even if optional.
NeilP
Post by NeilP » Feb 29, 2012 2:32 am
Won't be a problem at all.
Use a longer pipe and use this lever and unit on the back. You will just need to change the mounting adapter
Tektro do sell them for both front and rear. I wanted to get them but on the Tektro web site they are labelled as OEM only
http://www.tektro.com/_english/01_produ ... rt=1&fid=1
or ask the e-bay seller if they can get the others in the range..maybe the bigger Dorado e-moped range
Neophyte
Post by Neophyte » Feb 29, 2012 3:00 am
Rear and Front available.
[ 160mm rotor only ]
With some re-wiring necessary for some systems...
[ Sensor control designed for Bion-X system ]
http://cyclepath.ca/shop/product_info.p ... ke-p-15581
Andje
Post by Andje » Feb 29, 2012 6:16 am
http://www.hygia.com.tw/liveshop/index. ... duct_id=82
This company also has hydro brakes with e switch available. The link here takes you too hydro e brakes designed for tadpole trike front wheels; one hydro lever controls front and rear brake and e brake switch as well. They have solo-calliper ebrakes as well.
Norco 125 Dirt Jumper
100v 15ah Lipo Backpack
lyens 18 fet, 100v 100 amps, R12 Regen
x5304- 95km/h
https://endless-sphere.com/forums/viewto ... =3&t=24594
Norco A-Line Park 2009
144v Kelly 300amp
5403/ future HS60
https://endless-sphere.com/forums/viewto ... =6&t=35652
grindz145
1 GW
1 GW
Post by grindz145 » Feb 29, 2012 9:05 am
Oh man, those Tektro Dorados are awesome. Very good ebike size.
grindz145
1 GW
1 GW
Post by grindz145 » Feb 29, 2012 9:28 am
Andje wrote:http://www.hygia.com.tw/liveshop/index. ... duct_id=82
How is the quality on these? Decent?
Andje
Post by Andje » Feb 29, 2012 10:57 am
got to admit i have no idea; I was planning on ordering them only because i need two brakes controlled by one lever. I may just daisy chain the hydro calipers and run a normal hydro lever with a hall sensor and a magnet glued on. If I do end up ordering from hygia I'll report on them for sure. I can tell you that the company seems quite on the ball; I emailed them about their online store with a question about hall options and they actually added a "halls" ordering button on the site by the next day.
x5304- 95km/h
144v Kelly 300amp
5403/ future HS60
hjns
Post by hjns » Oct 01, 2012 5:48 pm
NeilP wrote:Any one used one of these?
is that about it?
Just bought them. We will see how it goes when I get my hands on them. Intend to use on Juicy Seven (wife bike) and Elixer Seven (cromotor commuter)....
Installation guide (pdf)
Henk
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible. T.E. Lawrence
MattyCiii
Post by MattyCiii » Oct 01, 2012 8:39 pm
I have a few of those. Plan to put two on my green bike, which has hydro brakes front and rear. To date however have only installed on one brake on my folding bike.
Installation and bleeding went fine. Sadly I left too little hose between brake and pressure switch, making it a bit difficult to complete my bleeding. My problem (to date) is that the switch is basically too sensitive - it registers as just-about-active when the break lever is not closed at all. So when I attach it to my CAv3, it flickers like a dying fluorescent light bulb. If I take my break lever and pull it AWAY from closed, the switch reads "open" and I can ride. No good! So, I have an overly sensitive break pressure switch.
Options:
1) I bought a few of these... I can install another one. And bleed. PITA.
2) I can maybe bleed out a little pressure from the system - maybe open the bleed valve, close the brake lever 1/4", then close the valve. Create an "under pressure" start point. Have not tried that yet, too many other things to do.
For now, my brake switch stays disconnected :(
