hello , i read in the forum that you can run the bafang motor pmgr at 72 v !! Is it reliable?
Actually i ve a bafang pmgr ( http://www.szbaf.com/product.asp?id=6 ) or originaly 30v/ 15 A i run it at 50 V (12s lipo)/15A. The controleur is an ecrazyman 48v/15A 6 fets controleur. I program it with xpd to have exactly 15A at max trottle. Original programation of ecrazyman controler send 20A so 1000W to the motor, i make some run at 1000W and the motor still alive!
It s ok it run since 6 month with no problem! top speed 45 km/h (28 m/h) and max power at full trottle : 750W.
I buy an 72v/45A ecrazyman controleur an i ll try it on the bafang with 18s lipo (75v max ) and program max current 15 A do you try this configuration? it say in the forum max voltage 72v/ 30 a!
is it reliable? i think i ll keep the trottle to have only max power to 750 w?
thnks for the info
thnks for the info
