Laptop power supplies as chargers..
Ypedal   100 GW
Post by Ypedal » Jul 11 2012 7:50pm
Still on my quest for a cheap, simple, small, 100v lipo charger.. this is like the pick 2 but not 3 deal with batteries.. frustrations..
Ok.. so after repairing a MW supply:
http://endless-sphere.com/forums/viewto ... =2&t=41160
I put 2 of them in series, set the voltage to 99.5v and hooked it up to a CA and a 24v cell pack.. all was well for 0.8ah at 8 amps until one of the units i " fixed " quit.. fan stopped and no output.. .. will deal with that some other day.
I happen to have a box full of these laptop power supplies, specifically a bunch of HP 18v 3.5amp units..
ES site status page:
Ypedal   100 GW
Re: Laptop power supplies as chargers..
Post by Ypedal » Jul 11 2012 7:55pm
The output wires are made of this stupid braided , shielded cable stuff, the braid i hate because you canot solder it ( i've tried .. not with a bigger iron yet.. but anyways.. not important ) .
see:
after much futzing i managed to crack one open using a dremel and a cutting wheel..
so i can un-solder the braid crap, and solder on some 14 awg silicone in there with andersons.. or similar..
I'm borderline electronics retard, so i got no clue, however, me think that if i hook 3 of these in series i get 60v, hook that in series with the non-dead MW 48v unit tuned down to a total of 100.0v i got myself a 3.5 amp 100v unit..
using 5 of these, would make a very small, compact, weatherproof on-board charger.. for opertunity charging ....
anyone ?.. yay.. nay ?
Harold in CR   1 MW
Post by Harold in CR » Jul 11 2012 8:12pm
I have a shitpot load of Laptop chargers, at 10.8 volts. I seriesed 4 of them to charge 36V Battery. Works great to 42V HOC.
Did 3 the same way for 24V charge and 1 won't do the charge. Tried 3 different chargers, all do the same. These are NEW. :roll:
Thanks to Justin, the forum is open source and NON-commercialized.
torqueon   1 kW
Post by torqueon » Jul 11 2012 8:37pm
I have had good result using Del 3r160 supplies for the old dell optiplex compact desk tops. Been using them for about a year, 4 series to charge a 36 volt pack.
seems they may work well 9 in series for 100 volts.
You must cut the ground on all except for one, and all must be powered up at the same time
I wanted to post some pic and drawings for you, however can,t seem to make it happen! right now. I have posted much detail about the P S U in the past here.
Ask if your are interested, and ill post more info later
Ypedal   100 GW
Post by Ypedal » Jul 11 2012 9:00pm
torqueon wrote:I have had good result using Del 3r160 supplies for the old dell optiplex compact desk tops. Been using them for about a year, 4 series to charge a 36 volt pack.
You must cut the ground on all except for one, and all must be powered up at the same timeI wanted to post some pic and drawings for you, however can,t seem to make it happen! right now. I have posted much detail about the P S U in the past here.
I was hoping someone would mention this part, i dont fully understand why this is, but i konw it's important .. " Isolated " .. vs " not isolated " ..
I thought this only mattered if the units had metal housings and made contact with each other? ( had this happen on nimh packs with Hi-Power chargers... blew fuses if the chargers touched ) ..
more info welcome !!!.. pls ! ( or i will be learning by experiments in the driveway and power bars... neighbors look at me with fear when i do this .. it happens quite a bit ! )
dnmun   100 GW
Post by dnmun » Jul 11 2012 11:04pm
with the SMPS chargers the output is isolated from the input.
if the cord has a grounded lug on it, then you can check to see if the ground is connected to the negative ouput with an ohmmeter. i have seen this case with a three pronged plug charger.
if it is a two pronged plug, the output is isolated.
Lebowski   1 GW
1 GW
Post by Lebowski » Jul 12 2012 5:06am
torqueon wrote: You must cut the ground on all except for one, and all must be powered up at the same time
Some of the more fancy laptop supplies (Dell) have a high-ohmic resistor between the input
and output side of the supply. I think this resistor is necessary for the startup, that some
sort of signals must be present at the output side for the input side to start and work.
I can imagine this is where the 'all must be powered up at the same time' comes from.
dnmun   100 GW
Post by dnmun » Jul 12 2012 8:44am
the resistor on the output is a draindown resistor across the output caps so there is no voltage remaining on the plug when off. of course if the 'adapter' is left plugged in then the charger pushes current equal to that draindown current all the time.
dogman dan   100 GW
Post by dogman dan » Jul 12 2012 1:38pm
Cheap as you find those at the garage sales, too bad it's not simple enough for the likes of Dogman. Be nice to have an opportunity charger more built to get knocked around, and that cheap!
Can't solder a wire, that's why god made wire nuts. Or use a crimp connector.
pwbset   1 MW
Post by pwbset » Jul 12 2012 2:04pm
I tell ya if someone got into the turn key, adjustable & affordable (re: no china shipping $$) 18s-24s Lipo charging business they'd make a killing... I'm at 18s now, but want to do 22s-24s since I have some extra packs, but I'm no good at modding stuff like meanwell 48s nor do I want to shell out for a couple additional ecitypower chargers set to one voltage...
...there must be something out there to cheaply fill out needs. *sigh*
Ypedal   100 GW
Post by Ypedal » Jul 12 2012 2:44pm
These units are small for 3.5 amps, how they hold up at full power i dont yet know, but am about to find out..
best of all.. free !
Ypedal   100 GW
Post by Ypedal » Jul 12 2012 5:06pm
torqueon   1 kW
Post by torqueon » Jul 12 2012 10:13pm
The dell 3r160 are good for 8 amps, and you can vary the volts from 3.6 to 12 volts by installing a poteniometer, so no need for a meanwell. Had 6 units shipped to my door for $30.00 + 3 that i found in the trash.
There are 6 wires on the output side, (red and brown, are +) (black and white, are -) Yellow and green are sense wires
Wire in a potentiometer, wiper to the sense wire and you got yourself a 3.6 to 12 volt supply
These units will cut out if over loaded, if that happens remove load and reset the dells by powering off, about 10 seconds, power back up and reset to a lower voltage and try again. An ampmeter a big help here.
The power output will drop as the batteries charge and as the dells warm up, so you have to readjust the pots through out the charge.
To the credit of E S I have managed to build a circiut to maintain constant current, still work in progress.
cwah   10 GW
Post by cwah » Jul 13 2012 1:51am
why do we need current constant for charging?
Ypedal   100 GW
Post by Ypedal » Jul 13 2012 8:43am
cwah wrote:why do we need current constant for charging?
Reason i'm using these in series with a meanwell is that the laptop supplies will max out at 3.5 amps and keep the meanwell from overloading and melting down. ..
The Nano packs can take the current ( like.. 5C on a 13ah pack = 60 amps if i could afford that big of a supply ) but 3.5 amps is good enough for me and healthy for the pack.
the point here is to get it done ( reliable ) , and do it cheap.
dnmun   100 GW
Post by dnmun » Jul 13 2012 9:00am
you can use two in parallel to get 7A current limiting too. or three is 10.5A current limited.
Ypedal   100 GW
Post by Ypedal » Jul 14 2012 1:07pm
ok.. so update time.
I soldered a + and - lead to the units ( using recycled andersons from my stash of cut-wires, this is a " cheap and recycle " project after all ) ..
put the plastic housings back on and used filament tape to keep them tight, i figure the plastic needs to make contact with the metal shell to shed heat.. and air gap would be bad..
hooked it all up in series on a power bar, ( one of the 3 units has the ground pin missing already, the other 2 have them, and i left them be for now ) ..
I have a 12ft lenght of 10 awg silicone wire going on here, as i plan to put the charger on the shelf and run the wire down to whatever bike i'm charging from the garage..
and, so far, cha-ching !
Ypedal   100 GW
Post by Ypedal » Jul 14 2012 1:08pm
Keeping a clos eye on this.. heading back to the garage to monitor things.
Ypedal   100 GW
Post by Ypedal » Jul 14 2012 2:08pm
CA just hit 0w and put 2.7xx ah back into the pack.
the hottest the laptop units got was 62 celcius :shock: but they kept on ticking...
cell voltages range 4.11 to 4.17v ( from a well worn out pack, 8 of these cells have been pricked with a needle and de-puffed about a month ago.. still running them in 100v 5ah at 100 amps on a 9C setup ( full 20C rate ) ..
dnmun   100 GW
Post by dnmun » Jul 14 2012 3:43pm
what did you use to seal the hole from the needle? did they puff up again after that or stay flat?
Ypedal   100 GW
Post by Ypedal » Jul 15 2012 12:41pm
dnmun wrote:what did you use to seal the hole from the needle? did they puff up again after that or stay flat?
I used a tuck tape ( the red stuff used on home vapor wrap, very strong red tape ..
http://indoorgardensolutions.com/index. ... tail&p=332
After pushing the gas out using a piece of wood, sealed the pinhole, then put back in the shrink wrap shell, taped that, then put the 4x 6S packs in compression and tapped the mass into a solid pack, it still swells a bit but has been working ( hard ) for the last bit, no trouble yet.
Ypedal   100 GW
Post by Ypedal » Jul 16 2012 8:26pm
i seem to have misplaced my digicam, :evil: .. but i'm sure it will eventually show up.. it's a sign that i need to stop everything and start cleaning.. but so many projects near completion.. while so many others waiting to be started... means cleaning and organizing are low on the priority list.. i'm not proud of it.
So since i now have 3 charge cycles from the franken-charger and it looks like a stable 4.5amp 100v ( 450w ) unit, i went digging and found 3 identical cpu heat sinks, nice chunky aluminum, one for each laptop unit....also got some aluminum stips and once i tidy up the wires .... should be golden.. i can then start work on another unit ( so many 100v bikes, so little time )
Ypedal   100 GW
Post by Ypedal » Jul 18 2012 7:13pm
Found my camera !!!
I hope this helps keep them suckers cool enough to keep on running....
Used some thermal paste, clamped them down and jbweld on the edges to keep them in place..
then I plan to make some sort of bracket to secure them to the MW unit.
Ypedal   100 GW
Post by Ypedal » Jul 19 2012 3:24pm
dnmun wrote:with the SMPS chargers the output is isolated from the input.
I just checked this, and Yes, if i check Ohms from the AC ground to output Negative, i get 3.6k so these are NOT isolated...? right?
So now that i've removed the top half of the plastic shell, and attached heat sinks, does this mean the heatsinks can not be allowed to touch ? or do i zap myself if i put my hand on the unit ?
I plan to cut the power cords from all 3 units, solder the Live and Neutral's together, tie them to the L and N from the meanwell , leave the ground out of it ?..
suggestions anyone ?
Ypedal   100 GW
Post by Ypedal » Jul 20 2012 3:06pm
not quite done, but starting to look right.
