Tostino's water cooled 36 fet infinion
Arlo1   100 GW
Re: Tostino's water cooled 36 fet infinion
Post by Arlo1 » Nov 03 2012 10:12pm
tostino wrote:Well my luck has been pretty crappy lately, tried to go on a ride today to see how everything holds up, got about a mile down the road, and the motor stopped working. I got a little shutter, and then no throttle response at all.
I believe a hall sensor went bad in my motor, and it wasn't actually a controller issue this time (fingers crossed). I hooked the halls upto a 2s battery, and measured the output. Two of them went from 0-7.2-0, the other went from 0-2.4-0. Seems like an issue. Not too sure if that would cause the controller to give no throttle response though =/. No shorts on the phases though.
If its a sensored controller then its most likely your problem. Remember they work on 5v so the one going to 2.4v will likely be 1.5v or less with 5 volts run to it. Sounds like a bad connection. I melted the solder off mine once lol. The controller is most likely set up to look for 0-.5v for a 0 (off) signal and 4.5-5 for a 5v (on) signal or something of that nature so it wont pic up misfires from noise in the wires.
Does your project need a high performance motor drive, battery charger or other power electronics developed? Let's talk!
www.powerdesigns.ca
Leaf motor controller build. http://endless-sphere.com/forums/viewto ... 27#p963227
YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
Support me on Patreon. https://www.patreon.com/user/posts?u=6842045
http://www.undergroundelectrics.ca/
tostino   10 kW
Post by tostino » Nov 03 2012 10:23pm
Yeah it is sensored, and that is what I assumed, i've just never had a controller refuse throttle input and not try and spin the motor, even when hall input was off.
tostino   10 kW
Post by tostino » Nov 09 2012 2:36pm
frock me...
I got my motor sensor fixed (was toasted), and wanted to see if that had fixed it, so I got everything plugged in, then I connected my battery to the controller, and had flames shooting out if the box within seconds.
I disconnected the battery as soon as I noticed something off, and tried to see what had happened. None of the fets were blown, but where I soldered one of those low ESR caps, and had one of the large electrolytic caps, they had blown, and left a hole in my board. Now I have 27 ohms between + and -.
Now i've gotta see how I can transfer my parts from one board to another, because I can't imagine things being good on that thing any more.
This frocking sucks. This completely frocking sucks.
tostino   10 kW
Post by tostino » Nov 09 2012 4:51pm
Any ideas how to de-solder the fets from the board? trying to use the toaster oven on Broil now, but it doesn't seem to be working.
Here are the pics so far ='(
IMG_20121109_150012 (Custom).jpg (188.47 KiB) Viewed 918 times
IMG_20121109_150022 (Custom).jpg (205.65 KiB) Viewed 918 times
IMG_20121109_150133 (Custom).jpg (139.27 KiB) Viewed 479 times
IMG_20121109_161505 (Custom).jpg (193.49 KiB) Viewed 918 times
IMG_20121109_161606 (Custom).jpg (185.79 KiB) Viewed 918 times
tostino   10 kW
Post by tostino » Nov 11 2012 4:03pm
Toaster oven worked. Just had to put it a bit closer to the burner. I've got the new board almost built up now... I still am not 100% sure what happened, possibly the leg of one of my caps jumpered the + & -, and blew everything to hell? I really don't know. I may skip out on the big electrolytic's on the bottom of the board this time.
