420A 24S ESC by aliens
crossbreak   100 MW
Re: 420A 24S ESC by aliens
Post by crossbreak » Aug 11 2013 9:22am
why would someone use more than one shunt?`I saw my sensorless 24xirfb-3077 has 4 shunts in parallel, thought that was just for making it more simple to produce :? It eats 45-85amps without hassle from a dead stop and does not appear to die someday.
kelvinscott76   1 W
Post by kelvinscott76 » Aug 11 2013 10:19am
crossbreak wrote:why would someone use more than one shunt?`I saw my sensorless 24xirfb-3077 has 4 shunts in parallel, thought that was just for making it more simple to produce :? It eats 45-85amps without hassle from a dead stop and does not appear to die someday.
hey crossbreak,i have just one shunt a huge one rated for a peak of 600amps which is good enough for me,it will start from a dead stop on hills as long as you have enough battery power ,it might stutter very little on hills but it will go after that
Experience is the best teacher,don't be deceived
kelvinscott76   1 W
Post by kelvinscott76 » Aug 11 2013 10:21am
crossbreak wrote:hey kelvin,
thx for your vid, finally someone who adds something useful :roll:
One question: Can you accelerate hard from a dead stop on a hill without using pedals? Does it struggle? What current limit did you set in CA?
My current limit was set to 500amps
crossbreak   100 MW
Post by crossbreak » Aug 11 2013 10:49am
thx for the rapid answer....500amps! Your motor wont eat that :lol: What amps/watts do you see during acceleration?
kelvinscott76   1 W
Post by kelvinscott76 » Aug 11 2013 10:51am
crossbreak wrote:thx for the rapid answer....500amps! Your motor wont eat that :lol: What amps/watts do you see during acceleration?
i have used up to 296amps during acceleration and had a peak of 345amps on a fully charged 75volts battery
megacycle   100 kW
Post by megacycle » Aug 11 2013 5:17pm
circuit wrote:
crossbreak wrote:One question: Can you accelerate hard from a dead stop on a hill without using pedals? Does it struggle? What current limit did you set in CA?
I think the real question would be how many current shunts does it have. If the answer is 1, then answer to your question is yes, it struggles and will blow up some day.
With that in mind, I would like to see a test (video) of full throttle at stall, for at least 10 seconds.
Since it's not a generic ebike controller, with all the bells & whistles how easy would it be to fit them?
Gokart A123 80V
300A Kelly Controller
PM72301 motor
15S lipo
mongoose frame
mini monster controller
500W funboy
Speedict Mecury
kelvinscott76   1 W
Post by kelvinscott76 » Aug 11 2013 7:13pm
Here is the alien power system controller temperature after a 10miles ride 35 degree celsius
kelvinscott76   1 W
Post by kelvinscott76 » Aug 11 2013 7:15pm
Here is the motor temperature after a 10miles ride 85 degree celsius
kelvinscott76   1 W
Post by kelvinscott76 » Aug 11 2013 7:16pm
Here is the 60mph top speed for the evening
kelvinscott76   1 W
Post by kelvinscott76 » Aug 11 2013 7:18pm
Here is the maximum current draw by the cycle analyst for the whole 10miles ride 319.1amps
kelvinscott76   1 W
Post by kelvinscott76 » Aug 11 2013 7:20pm
I have given more than enough evidence that this esc is good and i don't make false claims like some member said i did,so if you doubt it buy one yourself and do a personal test because i've done my best
circuit   100 kW
Post by circuit » Aug 12 2013 12:04am
You don't give false claims, however you don't give enough information. These test don't say much about EV suitability.
smart and Tiny BMS solution
Visit my blog. Personal projects: Clean Peugeot conversion | Ultralight enduro
Any and all information, such as texts, specifications, drawings or other material that I post are to be used only as a reference for personal, non-commercial projects ONLY. Any republication for personal or commercial needs must be agreed on individually. Use of any information, that I post, for commercial purposes is strictly prohibited.
Dauntless   100 GW
Post by Dauntless » Aug 12 2013 1:33am
While I agree with Crossbreak that this is all interesting and you obviously are making progress, what Circuit is saying is you don't have enough info for us to repeat the experiment. ES is like a scientific journal that way.
Do you already have a thread on your bike? That might be interesting.
- Arthur C. Clarke
crossbreak   100 MW
Post by crossbreak » Aug 12 2013 3:24am
An own thread, that would be great! We want to know Battery chemistry, number if cells, rim size, BMS used, shunt value, min voltage during test etc. etc. :D
Thx a lot for all of you info, you already helped me a lot. You can save your time uploading pics of CA and IR-Temps, this can be counterfeit very easily anyway. If you just tell us exactly your test conditions we would be very happy :)
Thud   100 MW
Post by Thud » Aug 12 2013 3:51am
methods wrote:Luke is far from the only guy around here who can string together a few packs and load down an ESC. How about someone pipes up who thinks they have the time, gear, and money to run the test. I will get the equipment from Luke and ship it to you at my expense.
Problem solved.
Who wants to do it?
If I land this dream job I am focused on and my coffers fill to the brim with fiat currency then I will do the test. Ain't rocket science - and I have all the gear. Might even be willing to loan some gear local if that works out.
-methods
Has methods made good on this yet to anyone?
If not, i'll throw my hat in the ring.....the only "gear" i have is a stand alone CA & the bully track bike to test it in its worst nightmare senario.
(This bike has 5 hv160 notches in its belt)
If it survives 5 runs at full voltage & 25ah (rc lipo) on the test track, i'll forward the thing to the next guy on the list for more empirical testing. (Prolly arlo1 so we can watch it run a colossis on a dyno) he has a good record for documenting things.
The only reason being, i know how much easier it is to run a hub motor on these controllers....etard has a crap ton of miles on an Castle ice100 running a fwd hubbie.
Lets see how the controller feels spinning a motor @ 9k rpms instead of 860.
The math works out: 9k/7pole prs=63,000erpm vs 860/23 pole prs=19,760erpm.
Figuring a 20" wheel is still only 1109 rpms. only a 3rd of the stress I'll show it.
Switching losses are a b#%*!
get some......
kelvinscott76   1 W
Post by kelvinscott76 » Aug 12 2013 7:57am
Join my electric community on facebook to learn more about my bike and share your own idea and opinion concerning any electric vehicle related topic https://www.facebook.com/groups/201931886642580/
kelvinscott76   1 W
Post by kelvinscott76 » Aug 12 2013 8:21am
My very first test setup was 75volts 20AH lipo battery which gave a top speed of 72mph but after damaging a 5AH Battery out of 20AH my top speed range has been between 60-65mph,my rim size is 18inch but with an overall wheel diameter of 24inches due to a fat motorcycle tire,my shunt value is 50mv/600amps=0.0833mohms after the calculation i tried to do a test in comparison with my dc clamp meter and it seems to be very accurate,all my tests so far has been done with a 75volt battery and i get a high voltage sag from 75volts to 69volts or even lower during acceleration,i haven't done a dyno test or a graph test because i don't have an access to those equipments/facilities so far my real test has been on the road and i've really smoked the motor :D
zombiess   100 MW
Post by zombiess » Aug 12 2013 10:49pm
I'm trying one out for the hub motor guys, just ordered today.
jansevr   1 kW
Post by jansevr » Aug 13 2013 8:39am
sounds great zombiess, what motor specifically? it will be nice to finally see some real torture tests and see what it can do :D
zombiess   100 MW
Post by zombiess » Aug 13 2013 10:43am
jansevr wrote:sounds great zombiess, what motor specifically? it will be nice to finally see some real torture tests and see what it can do :D
My low inductance high KV Cromotor. 30uH and 18KV. I already have some fet temp and amps data from the Xie Chang controllers running this motor on 75v up to 180a during acceleration. Holding 50 mph take around 80a continuous. I am feeling pretty good about it working based off the video of the poster in here who used a large hub motor.
kelvinscott76   1 W
Post by kelvinscott76 » Aug 13 2013 1:14pm
Zombie be careful with your test because that controller is capable and strong enough to fry/toast your windings in your cromotor :twisted:
jansevr   1 kW
Post by jansevr » Aug 13 2013 3:41pm
i was hoping you were gonna say your cro - this should be awesome to see what that little controller can do! can't wait for the vid/data :D
zombiess   100 MW
Post by zombiess » Aug 13 2013 4:25pm
Not without some serious work on my part, the phase wires would most likely fry first. It has 30 strands of what is probably 20AWG wrapped 2 times around each tooth giving it the equivalent of at least 6 AWG and closer to 5 based on circular mils. I've run 180A through it as hard as I could on/off the throttle for several minutes.
Can't wait to try it out, this will be my first experience using an "RC" controller on a hub motor. I'm looking for alternatives to the Xie Chang controllers (but also working on some development for them too...).
kelvinscott76   1 W
Post by kelvinscott76 » Aug 13 2013 6:02pm
i have 6 10awg wire going through my motor axle,2 for each of the phases so my phase wire never melted or did i have any issue with the phase wires :D
chroot   100 kW
Post by chroot » Aug 13 2013 7:26pm
@zombiess - sweet I can't wait to see your test controller with the cro motor. If you find the controller is perfect for cromotor then I will follow your step. I probably put 150A max for my cromotor.
*subscribed*
