Was very pleased with myself and told the wife, she just chuckled and said... "what next, fire?"
Seriously, i used a one cross / underlaced pattern , 13 guage sapim spokes on a mavic EX729 heavy duty mtb rim with a bpm 8fun motor.
I thought that my initial set up for adding spokes was worth a mention. I used a car tyre from a 17" wheel to hold the rim and a stiff cardboard box with space inside for axles to support weight of motor. Infact the box was the one that the motor came in.
I was apprehensive at the start and it did take a few hours in total, but it wa one of the most satisfying things i have done bike building. I used 190mm spokes.
There were two errors i made. One was lacing the spokes which did not leave the maximum amount of space to attach pump to a valve, but there is enough room.
Two, i could have ordered 1 or 2mm shorter spokes for the left hand side as the bpm motor is 5mm out of centre. I decided that loosening one side and over tightening the other side to 'dish' the motor and rim was not for me. I would rather the spokes are done to fairly equal tension.
By the way, i painted my motor black to go with black spokes and the rest of my bike. Yes i know NOW you can get black bpm's I used a special metal primer and hammerite smooth in a spray can. Lets hope it does not help to retain heat.
Any thoughts on any of the above?
Andrew
Andrew
