I would like my next bike to just be for me and my own selfish ideals. Not for fashion, or to blend in with the local Lycra bunch, or to ride on one of megacorp's next season must haves, and not to be even that practical, sexy or safe. I just want to go fast using as little as possible.
I always appreciate design that stretches the full potential from fairly modest materials, to me that's good design. Exotic materials seem to have a bit of a "halo" effect in regard to perceived performance advantages. eg.formula 1 uses carbon fiber and titanium, so if we make a penny farthing out of that it will be fast. No it will still be shit. I'm not arguing it will not be better than a cast iron one but maybe we should stand back and look at the design from a distance to see what the real issues holding it back are?
A very large chunk of any electric vehicles budget and weight budget is battery. Most of us spend more on battery than bike! I'm not going to whinge about batteries not being good enough, too expensive or "bigoil" or "patent owners" just keeps all the best stuff on a dusty shelf somewhere. I would just prefer to minimize the need for carrying so much of these heavy, expensive lumps around.
At commuter speeds of 60km/hr my down hill bike uses around 2500w or about 25km range with 1000w/hr of battery. If I reduce frontal area and improve its drag coefficient down around something like a competitive racing recumbent (around .035CdA) I should get around 250km!! on the same battery, or go the same distance and my battery costs dropped to just 10% of what it used to be. I know most of you get it and this is all baby talk but i have not seen any real max efforts for economy. Doctor bass did pretty well with around 200km distance? But i think it was weighed down with a fair whack of batteries, and rode real slow. But he set a good bench mark.
For the monoque chassis i looked at various materials and made some vacuum infused test panels of various cheap and nasty cores (paper honey comb,cheap blue polystyrene,end grain balsa(my favourite) and strip plank paulowina timber) and for fiber(bamboo, jute or burlap or hessian and fiberglass layups) w'll use a bit of carbon fiber in high load points. One of the drivers for material was also for rapid prototyping and to minimize the amount of sanding! The hessian looked really good,(well piss week compared to man made fibers) was cheap and had a "green " organic fiber look but it really drank the epoxy resin, around 55% by weight (fairly heavy) and so would need a good mold for resin infusion to keep the resin weight down. I am building a large yacht(it involves a LOT of sanding) and more sanding makes me want to punch myself in the face, and making nice composite infusion molds means LOTS of sanding, so i shelved that idea and choose strip plank paulowina or kiri. It looks like balsa but weighs about 290kg/ cubic meter compared with balsa's 150kg. It is plantation grown so encourages a market for planting trees not knocking them down and it was the cheapest $120 for all the timber needed to make the bead and cove strips 1/4 X 20mm for the body/chassis. Any way here's some photos of the fiberglass model i made 2 weeks ago. I have machined all the bead and cove wood strips, made the buck and strip planked one half of the body and scored a free GM 500W mag wheel motor 18inch (thanks Toolman) and it will probably be FWD to start with but will be able to fit large RC motors on the back. Please give comments or feel free to take the piss. this is a work in progress. P.S yes it does need trainer wheels for landing.
