tire replacement options
the schwalbe big apples on my surly big dummy are ready for replacement and was wondering if anyone could suggest a tire comparable in terms of wear,ride,puncture resistance.cost is not a issue as i am thinking of commuting on it this spring to work which is 16 miles one way so reliability is of utmost importance.mostly bike trail and suburban roadways.all opinions wecome.thanks.
Re: tire replacement options
If you want puncture proof and are OK with 2.0", look up schwalbe's marathon plus tires.
- Drunkskunk 100 GW
Maxxis Hookworms. Pretty much the only two tires this class are your big apples and the hookworms. But realy, it's like asking if you want the Strawberry blond supermodel girlfriend, or the platinum blond supermodel girlfriend. Either is going to be a dream to ride.
like the hookworms but also wondering about schwalbe crazy bobs,anyone have personel experience with them?
Hookworms are nice...I always seem to have trouble getting the Big Apples mounted evenly around the rim for some reason.
If you don't mind the extra weight, take your old tire, trim off the "rim wires" and place the old tire within your new tire then the inflated tire tube. It gives added puncture protection. I did this to my rear tires as they are more likely to become flat. I had 2.0 marathon plus and didn't like the feel of the road as I added more weight to the back. I made the move to a wider big apple tire and it's night and day when loaded down. I'd say stay with the wider tires for the added suspension.
Surly Ogre rigid 29er, rear 10T MAC @ 50V 25AH & 40A: 30mph road/gravel/hill machine
42" dual diagonal Eskateboard @6s & 90mm wheels
Next: eMTB @10-12s & 8"-12" pneumatic wheels; Got Strapped? d-(',')z
Schwalbe big ben, big apples or maxxis hookworms are all great choices. Some have also used the cst cyclops with success
Test Review Revise Repeat
Hookworms aren't the most flat resistant tires. Not like the marathons. And i'll agree, the marathon plus's don't have the best ride, but they are good for lower speeds and pretty much as flatproof as it gets for a bike tire.
If you go with hookworm 2.5's, there are tire liners that can be used to help prevent flats. I wouldn't run some without tire liners.
http://www.amazon.com/Mr-Tuffy-tire-lin ... B001J8HGM2
These seem to get good reviews.
- amberwolf 100 GW
- Location: Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Arm, Milky Way, Local Group
- Contact:
more info (list of threads)
http://www.endless-sphere.com/w/index.p ... _and_Tubes
If you found this advice helpful, supporting contributions are accepted here.
"if it ain't broke, improve it till it is"----Dog-Hauler Cargo eTrike SB Cruiser----The HI-Lebowski: a Lebowski SMD brain running a zombified Honda IMA Inverter: a HOW-TO guide----Cargo eBike CrazyBike2----General Blog
Been pretty happy with the Michelin Pilot Spot 2.3" tires. My rear one is almost bald after 1,600 miles, but I like the performance and looks. Only 1 slow leaking flat in that time despite riding through plenty of broken glass that accumulates on the under-used bike paths around here.
http://www.amazon.com/Michelin-Pilot-Sp ... B004JKEQB6
2.4 CST cyclops are great, $13 each. I have 600 miles on mine, the front looks almost new the rear looks about 60%
Specialized HR - 75 lb's
A123 26650M1 23S4P(75.9V Nominal) 7500W Peak
Infineon Lyen 12 Fet/45amp controller heavily modded pushing 110 Amps peak
Yescom Motor with upgraged phase wires (Golden Motor/9C replica)
thanks for all the feedback.has anyone heard of schwalbe returner 26inch tires,found them on calhoun cycles website.pretty cheap at 20$ a tire.what do you all think.i might pick up a pair and be a guinnea pig and post about them.unless someone can steer me to a better alternative.still considering crazy bobs.
After fiddling around with tires and still getting flats, I ended up with the Specialized Armadillo Crossroads. Toughest tire I've ever had. No flats/leaks of any kind. They wear like iron. I stopped carrying a spare tire kit because they've been so good.
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
like the look of the crossroads but a little worried about ride quality but that may be because i am used to the cushion of the big apples.still wondering if anyone knows anything about the schwalbe returner that calhoun cycles advertizes on thier website.would appreciate all feedback,thanks and happy v-day.
I run Kenda 1.95" street slicks with the heavy duty thick "slime" inner tubes - The tires appear much wider than 1.95" as they "mushroom" out at the tread and with the thick tubes have been bullet proof for me - also very affordable too!
1997 Gary Fisher HooKooEKoo Hard Tail MTB, 48V 1000W Yescom Rear Kit, 48V 15 AH Lifepo4 Sunthing28 Pack
Hookworms and CST Cyclops FTW on 5 ebikes. I never had tire flat for long time!
I have flat resistant taper, heavy duty tire tube and combine along tires. Love it!
Thank you Justin Lemire-Elmore - You are a HERO!
Tidalforce, Yuba Mundo V4 Cargo bike, Juiced Riders ODK V1 Cargo bike
English is my secondary language - ASL (American Sign Language) is my primary.
Itchynakers: Agree that Armadillo crossroads are about the toughest tires I've used. It took my wife and me about 4-5 years to wear out our first sets. (Wear out is not totally accurate in that two of the 4 tires showed more signs of dry-rot than of wear.) I've since moved to wider tires front and rear from the 38mm armadillos. My wife still uses her crossroads with her front suspension fork, but appreciates using a wider semi-slick on the hardtail rear for ride quality. Our two takeoff spare armadillos may well die of dryrot before she needs a new front.
- Location: Redmond, WA-USA, Earth, Sol, Orion–Cygnus Arm, Milky Way. Age: > yesterday < tomorrow
- Contact:
Hookworms, Armadillo, Marathon - all are pretty good. Big Apples are thin by comparision. I would lay down a layer of either Stop Flats 2 or Panaracer FlatAway Tire Liner + a bottle of Slime for extra flat protection.
Flat free since August 9th, 2011, KF
* My 2WD Garden Wall
* Kinaye MotorSports
* Epics: Going to California: 2011
I'm sorry. I don't believe this. There's no way a tire that big would only last 1600 miles. Unless your skidding it on every stop.outbackhack wrote:Been pretty happy with the Michelin Pilot Spot 2.3" tires. My rear one is almost bald after 1,600 miles,
408 front hub
21000+ miles on many sla's.
5 tires worn out
5 tires worn out
