It always dives me crazy when someone calibrates a shunt in that way
I guess it is a pretty reasonable way to do it - I am just bugged out about calibration.
If you have an iCharger then you should be able to calibrate it tits-on. I know you know the procedure - but it is about time to repeat it for the new folks.
How to calibrate the shunt value in your CA using a constant current source:
Collect an iCharger
Choose foam cut from the special modes (constant current)
Set the current as high as it will go - 20A or 30A
Set the voltage to something nominal - like 3V
Devise a way to Y into your controller ground wire
Hook your controller to your pack (remove the motor)
Turn the controller on with the CA hooked up
Hook the iCharger red wire to the controller ground Y (between the pack and charger)
Hook the iCharger black wire to one of the three phase wires (which are not connected to a motor - I always pick yellow)
Turn the iCharger on
As soon as the icharger settles on 20A or 30A write down the value on the CA
Shut off the iCharger
Go into the CA and find the shunt setting
Go find the CA Shunt Calculating Excel spreadsheet that is bobbing around here someplace
Enter the iCharger setting in the first column
Enter what the CA reads in the second column
Enter the CA shunt value in the red box
Then - enter the value that is calculated (the new shunt value) into the CA
Repeat the test and the CA should read +/- 5% or 10%
For increased accuracy use a Fluke DMM inline and keep the currents below 10A
What is happening is that the iCharger is driving a constant current in through the ground of the controller, through the shunt, up through the source of the lower mosfets, through their body diodes, out their drains, and out the phase wires. This is a perfect way to drive a known current through the shunt without taking the controller apart, without poking around taking bad voltage measurements with a DMM, etc. Originally posted by Justin - he suggested using a C battery
-methods
-methods
