Peak HP - Controller Have Enough Amps?
DrkAngel   100 GW
Post by DrkAngel » Feb 17 2013 2:11am
How to tell if your controller outputs enough amps to hit your motors full "peak watt output" - Horsepower.
You will need:
Speedometer & watt meter
Typically, a brushless hub motor hits maximum watt output at near 40% of no load speed.
Well, 1st you need to determine top no load speed.
Place speedometer on motor wheel.
Raise wheel and run at full throttle.
Observe top speed.
Peak motor output occurs at near 40% of no load speed (12mph if 30mph no load speed)
On road ...
Observing watt meter carefully, give full throttle.
Watts will stay the same till a decrease occurs.
This decrease occurs at the point where the motor accepts less watts than the controller can put out.
Repeat test, staying closer to this transition point, trying to pinpoint exact location, speed wise.
If this transition point is below the 40% of no load, then your controller is capable of full peak watt output - horsepower!
If higher, then you probably would benefit from a more powerful controller.
See - Determing Horsepower - Output Watts ... Simple Method!
Index - Homemade Battery Packs - Updated - December 2019
EBike Toolbox - Bargains! $
Endless Sphere Wiki - Lost?
DrkAngel   100 GW
Re: Peak HP - Controller Have Enough Amps?
Post by DrkAngel » Feb 18 2013 11:02pm
Example of controller being, and not being powerful enough to attain peak watt output.
11.6mph line is the 40% of top no load speed.
For this setup, the 25a controller will not allow peak watt output - horsepower. (Dark red line)
The 35a does. (Light red line.)
Golden 500w.JPG (128.04 KiB) Viewed 266 times
DrkAngel   100 GW
Post by DrkAngel » Feb 20 2013 11:49pm
Thread restored and most links repaired!
Thanks
~DrkAngel
