EBike Toolbox - Bargains! $
DrkAngel   100 GW
Re: DC Fuses 32v - 58v -80v - 125VDC
Post by DrkAngel » Feb 17 2016 9:09am
DrkAngel wrote: 58V DC fuses 15A - 150A 58V Female Cartridge Fuse Holder Source???
  • 250VAC Fuses 80-125V? DC Equivalent
  • 30A Slow Blow
  • 40A
  • 50A
  • 60A
  • 70A
  • 75A
  • 80A
  • 100A
  • 125A
  • 150A
    Note:
    250VAC = 80-125V? DC compatibility based on various claims and the ratings of multiple manufacturers with multi AC-DC compatible fuses
    Please test and confirm in safe environment before placing in service
Slow Blow fuses usually recommended for eBikes etc.
Check descriptions for:
Slow
Delay
Slo
Lag
125VDC Fuses are typically in a larger format and of limited selection
Most Common:
20A
30A
40A
50A
60A
70A
80A
100A
125A
[url=ttp://www.ebay.com/sch/i.html?_odkw=125vdc+FU ... a&_sacat=0]150A[/url]
150VDC Fuses
200VDC Fuses
250VDC Fuses
Most Common
30A
40A
50A
60A
70v
80v
90v
100a
300vdc Fuses
400vdc Fuses
500vdc Fuses
Fuse holders proprietary to fuse type selected.
Index
Index - Homemade Battery Packs - Updated - February 2019
Endless Sphere Wiki - Lost?
Htfan   100 W
Re: EBike Toolbox - Bargains! $
Post by Htfan » Jun 12 2016 3:08pm
Found this adjustable delay/interval timer Relay for my DIY MOT battery tab welder! Works well for my needs.
http://www.ebay.com/itm/SCHNEIDER-ELECT ... SwTdJXRUF6
"Try not to become a man of success, but rather try to become a man of value."
- Albert Einstein
DrkAngel   100 GW
Post by DrkAngel » Jul 02 2016 5:14pm
(1s-7s) 5 in 1 RC Li-Fe Lipo Battery Voltage Balancer Meter Discharger LCD display - ~$8
Unlike a very similar previous posting, this does have continuous metering.
IR meter function seems to work ... roughly, but should be used to compare like cells. (Same brand, capacity, model, charged voltage etc. ?)
Can't vouch for discharge or balance function.
Ideal for my 7s 25.9V 25.92Ah LiPo battery builds. Replaces 24V 10Ah (5-6Ah actual) oem SLA battery.
Will be mounted on my bars to monitor "fuel level" and bank voltages.
8 wire Ethernet cable adapts nicely.
Use multiple for more than 7s.
Testing battery drain (to operate continuously) with an old 3s 2000mAh RC LiPo.
Will post mAh use but should be negligible
Index
UPDATE: 24+ hour run test showed "87% - 67%" discharge of 3s 1500mAh RC LiPo test pack. ~300mAh/day continuous run. 12mAh/hour
Most important was that discharge was even over the 3 cells.
Better selection - 5 in 1 Smart Battery Meter - ~$7
sonnetg   1 kW
Post by sonnetg » Jul 17 2016 2:45pm
ok...i am not sure if these items are really bargains or not, but I am sort of digging these. I was looking for a fork mounted head light, and finally was able to find one which I could use. The head light is fairly cheap for $6 and works great. Both these lights claim to be compatible with volts ranging from 12v-80v, but I only tested it with 36v, and works great so far. The tail light isn't really cheap, but it doesn't seem to be a bad deal for $20. Only time will tell how it holds up over time. Will update again if I have any issues..
Head Light: http://www.ebay.com/itm/221641886624?_t ... EBIDX%3AIT
Tail Light: http://www.ebay.com/itm/321926749036?_t ... EBIDX%3AIT
Cheers.
alsmith   100 kW
Post by alsmith » Jul 19 2016 8:32am
what is the front light size? the listing just says 'as pic' - thanks
sonnetg   1 kW
Post by sonnetg » Jul 19 2016 6:25pm
The diameter of the light is around 5.8cm in diameter. The lens (or glass in this case) is 4 cm in diameter. It's almost the size as my old Lumotec IQ dynamo light (picture on the left), which I had to replace.
The LED light does not come with any fork mounting hardwares, but I had few spares in handy, so it wasn't an issue for me. I might replace this light eventually with another Lumotec ebike light, but those are not cheap by any means. This will do for now.
alsmith   100 kW
Post by alsmith » Jul 24 2016 8:30am
a phone charger project (-not even sure if this is the right thread for it). I'm not sure how practical it would be as you can add a usb outlet from your battery and it wouldn't be a massive load, but this would be less of a load! And cheaper than the $112 ( :shock: ) one it references on ebay.
Bicycle Cell Phone Charger (Wind Turbine with build in Battery)
or take it a step further-
http://www.instructables.com/id/Make-yo ... imate-Rid/
alsmith   100 kW
Post by alsmith » Jul 24 2016 8:34am
sonnetg wrote:The diameter of the light is around 5.8cm in diameter. The lens (or glass in this case) is 4 cm in diameter. It's almost the size as my old Lumotec IQ dynamo light (picture on the left), which I had to replace.
Thanks. I've got led lights with very small (<1") reflectors and the beams aren't very well defined so I'm looking for something bigger, but not too massive.
DrkAngel   100 GW
Post by DrkAngel » Sep 05 2016 1:21pm
DB sprocket.jpg (22.02 KiB) Viewed 4777 times
DrkAngel   100 GW
Post by DrkAngel » Sep 10 2016 7:10am
690V 32A ON/OFF/ON Position 12 Terminals Rotary Cam Changeover Switch
Battery A - B changover switch
22-44V switch
note: Provides positive disconnect of all terminals in neutral position!
EG. 24V 30A 1st gear >> 48V 15A 2nd gear
EG. 36V 30A 1st gear >> 72V 15A 2nd gear
Image - $16.60
Various (10A - 125A) on/off/on 12 terminal changeover switch
32A 3 position switch.jpg (54.68 KiB) Viewed 4749 times
999zip999   100 GW
Post by 999zip999 » Sep 10 2016 1:08pm
Can the 80v headlight run with my 24s 84 volt hot off the charger battery.
DrkAngel   100 GW
Post by DrkAngel » Sep 25 2016 1:41pm
Schwinn 26" kevlar tires w/continuous price tracking - price graphs are automatically updated!
Good quality affordable tires ... a great bargain, if you catch them on sale ...
Updated to reflect most recent year prices.
I built this "page" to help keep watch for best prices! - check daily to catch best bargains! Usually last 1 day, or less!
Schwinn MTB Tire with Kevlar, 26-Inch (B0030RMC10) - ≥ $15.43
Schwinn Cruiser Bike Tire with Kevlar (Black, 26 x 2.12-Inch) (B007XZ2OJ0) - ≥ $15.23
Schwinn Street Comfort Bike Tire with Kevlar (Black, 26 x 1.95-Inch) (B0088X3VL6) - ≥ $10.67
DrkAngel   100 GW
Post by DrkAngel » Oct 05 2016 8:34am
New (last?) supplier for lighted ring 18650 Zoomable LED light (or 3x aaa).
Includes bicycle holder and rear flashing light.
Essential for being seen! Strobe during day!
High at night is good for seeing up to moderate speed.
(Reverse mount for best balance!)
Image - $4.89
Update - Received item:
Good quality
Wide setting is slightly wider than previous alternative = good
It does have the spring for pos tip, allows recycled 18650 use.
w\Blue lighted ring - $4.89
d8veh   100 GW
Post by d8veh » Oct 05 2016 5:24pm
New wattmeter with included remote shunt. Also has low voltage warning:
http://www.ebay.co.uk/itm/181814316903? ... EBIDX%3AIT
DrkAngel   100 GW
Post by DrkAngel » Oct 29 2016 8:51am
Ryobi
18-Volt ONE+ Power Inflator $19.97 11/16
0-150psi
Great pump with 3 year warranty!
Fabulous price and warranty, but ... needs Ryobi 18V battery, or rig 5s LiPo?
Image - $19.97
Battery not included
TheBeastie   1 MW
Post by TheBeastie » Oct 29 2016 10:01am
Looking on these watt LCD meters on here I came across this one for only a few dollars more but claims to handle mother Russia level power of 200kw.. 400v 300A
Also has BMS features like cut off voltage or current limits..
So could be handy for those involved with heavy-duty EV projects. Something that can handle even close to 200kw of power for $32 is pretty good deal.
http://www.ebay.com/itm/DC-Battery-400v ... SwMtxXraAM
cerberpeter   1 mW
Post by cerberpeter » Dec 12 2016 11:36pm
For those like me who salvage old laptop 18650 cells - Battery Capacity Meter Discharge Tester - £3.60 (can be found at around 3.50-5 USD)
I was using hobby charger (Imax B6) to test all my cells, but this is very time consuming, so I bought 5 of these boards and assembled and ugly device for convenient discharging of 5 cells at a time. That effectively cut the needed time for testing by 10 :)
999zip999   100 GW
Post by 999zip999 » Jan 13 2017 3:48pm
Bump.
DrkAngel   100 GW
Post by DrkAngel » Jan 15 2017 7:59am
60w adjustable Soldering Iron + 5 Tips ≤ $12
Very handy for occasional work.
Durability not confirmed yet.
Might be advisable to purchase multiple and equip with different tips for different jobs. If one fails you won't be without.
Note: Check pictures to confirm which tips included - varies!
Digital Bicycle Bike LCD Cycling Computer Odometer Speedometer < $3
Has held up well to wet weather.
Read directions and keep for future reference!
DrkAngel   100 GW
Post by DrkAngel » Jan 28 2017 12:43pm
Variety of 12-80V capable LED lights
Confirm details and voltage in descriptions!
Image - ~$21 delivered
Unknown voltage or bulb type ...
Conversion to LED feasible, if necessary?
Handlebar Control Horn Left Switch Turn Signal Light Hi/Lo Beam < $5
DrkAngel   100 GW
Post by DrkAngel » Feb 16 2017 10:56am
update - 1st Hub motor kit I've recommended - (received but not tested yet - will update!)
Heretofore, I've built with gear reduction external motors and only "toyed" with mid-drives and hub motors
This offers nice features with great price from a USA ebay seller @ 99.1% approval with 500+ of this item sold
update - 6 Day delivery CA to NY (FedEx)
update - 7spd cogs 28-14T ATA(?) brand, spins smoothly, sounds OK - recommend 7spd 30-11T Epoch for better assist 20mph+
update - PAS capable variable assist by pedal speed, adjustable by magnets position and count (max 100% @ 60rpm 8:1, 6:1, 5:1, 4:1, 3:1, 2:1, 1:1 min 12% @ 60rpm) - guesstimated!
disc brake capable
Reversible!
update - Heavy spokes and rim - thin rim ≤1.95" tire size recommended
Kenda tube and tire 65psi
update - Instruction manual in English!
But most impressive ... to me ...
It is switchable from "legal" 750w=20mph to 1000w=28mph ... (TURBO Button!)
update - Controller labeled 26A - 1000w, 22A - 750w
48V-1000W/750w Electric E-Bike Hub Motor Rear Wheel Kit - <$155 delivered!
..... 28mph/20mph
Hub 1.jpg (191.75 KiB) Viewed 3982 times
Also available ...
I grudgingly note the 1000w front drive version ... though I view as being unsafe for the inexperienced rider?!
Same features as Rear kit
"Reversible" for eTrike?
48V Front Wheel Electric Bicycle Motor Conversion Kit 1000W E Bike Cycling Hub - <$160
Other sellers at similar price - check description for features!
Note: I have no monetary relationship to anything I list in this thread!
Just pointing out available bargains and handy items I've found...
If a mod feels this violates "for sale" postings rule, please message me and I will try to develop a specific "search" that lists multiple sellers for these specific item
alsmith   100 kW
Post by alsmith » Feb 18 2017 7:31pm
DrkAngel wrote:
I grudgingly note a 1000w front drive ... though I view as being unsafe for the inexperienced rider?!
I've never had a rear wheel drive bike, my front Crystalyte 5300 normally peaks at 2KW and is fine, if I connect batteries in series rather than parallel it's 4KW which starts to get a bit scary. If I get to build a new bike it will be rear wheel drive though.
LewTwo   100 kW
Post by LewTwo » Feb 19 2017 5:14am
alsmith wrote:
I've never had a rear wheel drive bike,....
Ditto ... and I am very happy with mine.
The more I learn the more obvious the immensity of my ignorance becomes.
Weight Wennie E-Bike https://endless-sphere.com/forums/viewt ... 3#p1173723
Shaft Drive Grocery Getter https://endless-sphere.com/forums/viewt ... =6&t=90718
...and thanks to Justin!
DrkAngel   100 GW
Post by DrkAngel » Mar 28 2017 12:32pm
12V-99V Electric Scooter E-Bike Throttle - $12
Handy
voltage monitor
and
throttle key lock!
Update - Red LED is worthless in bright daylight!
Key switch was not reliable through LED circuit, but spare wire can be used as positive key function.
(Waiting on 2nd sample for disassembly and alternate wiring. will document ... have blue LED that might replace for better visibility.)
Left hand 12V-99V throttle with 3 position switch, as turn signals or other? - $12
Throttle lock.jpg (84.64 KiB) Viewed 3523 times
DrkAngel   100 GW
Post by DrkAngel » Apr 02 2017 1:05pm
Innovative, after you get passed the heresy? of a left hand throttle ...
Looks to mount on a standard bike nicely.
Supplies handy turn signal capability
and
right handed rear shifting without throttle interference.
