its_me_jason
- Joined
- Mar 8, 2013
- Messages
- 77
I attempting to build my own trail head light (not for street use as it would be way to bright.) I ride early in the morning on these trails, like 4am so there is only wildlife on the trail ( dear, raccoon, fox, rabbits ) no people.
Does this look like it might work?
36V 15AH PING
to
Anderson connection (this is how I would turn on the power to the unit, as I think 36 volts would blow any Chinese on/off switch.)
to
Converter DC 36V Step Down to 12V 3A Power Module
Input Voltage: 15-50V DC
Suggested Input Voltage: Below 40V DC
Output Voltage: 12V DC
Output Current: 3A
to
DC-DC 100W Constant Current Boost Step-up Module Mobile Power Supply LED Driver
Input voltage :11-35V
Output voltage: 11-35V (adjustable)
Output Current: 10A (MAX)
Input Current: 10A (MAX) (Please enhance heat dissipation if more than 10A)
Output power: natural cooling 100W (MAX), enhance heat dissipation 150W (MAX)
to
(two of these guys, yes I know I’ll look like an aeroplane landing )
50W White 4600~4900LM COB LED SMD Lamp Light Bulb
DC Forward Voltage (VF): 30~34Vdc
DC Forward Current (IF): 1500mA
Viewing Angle: 140 Degree
Color Temperature: 6000~6500K
Intensity Luminous (Iv): 4600~4900LM
Single COB LED Chip Size:45?m
LifeSpan Time:>50.000 hours
to
(two of these as well)
LED 44mm Lens Reflector Collimator with Base for 10-100W LED Lamp Blub
Angle: 30-130 degree
Diameter: 44mm
Material: optical glass
Light transmittance: 99%
Compatible for 10W-100W LED spot light, automobile lights, DIY projecting lamp etc.
Service temperature range up to more than 400 degree Celsius
Dimensions: 44mm x 19mm
36V 15AH PING
to
to
Output Current: 3A
to
to
to
Diameter: 44mm
