mi7d1
Had a problem last night. While attempting an alternate route which includes several hills, my motor appeared to stop working 11 miles into the ride. When I twisted the throttle I had no or very little forward momentum. The motor sounded like it was turning, I could hear what I call a growling. This afternoon I put the bike up on the work bench to look into the problem. The wheel is turning but there is a difference than before. If I grasp the wheel and hold it while applying throttle I can hear the growling. A month ago if I did the same thing the motor/wheel would jump in my hand and click on and off. Turns out it was the low torque of the motor and I didn't realize that I could hold it still. There was no growling back then only a popping on and off. Now just growling and it doesn't stop until I release the throttle. Does this sound like a controller issue? I was under the impression that a single hall effect sensor gone bad would cause the wheel to spin erratically and multiple failed hall effect sensors then the motor run wouldn't turn with an instant start controller. I'm not sure of the symptoms of failed mosfets. Ideas appreciated.
Thanks,
Thanks,
