Deepkimchi
Make sure y'all are doing regular checking of axle, rack etc bolts. Did mine and found the rear rack (supporting my 25 lbs of 80V) was pretty loose. Rear and front axles okay.
Also tried to add a cutoff switch but started having problems with connectors (and one battery terminal was loose - the older FalconEV pack that had the loose terminal when I bought it).
Got my switch and tail-light installed also.
DK
DK
